nwoods
I have a Land Rover LR3, and I am thinking of installing a plywood floor into the rear cargo space and mounting tie down points to it. I do not have the 3rd row of seats, so I am not too worried about removing the flooring very often.
I have purchased the Slide N Lock system from Sierra Expeditions (nice vendor!)
My question is: What thickness and grade of plywood should I use?
Can I get away with 1/2" (15/32's) instead of 3/4"?? What works for you guys?
TIA
PS: I should add that I intend to secure this new flooring to the existing hold down points already in the LR3. There are 4, one in each corner. I thought maybe I'd use a trick learned from TravelToad (on other forums), buy using a gate latch:
TIA
