Which wood should I use?
DrMoab
On the tailgate of my new trailer, the guy who built it used 1/2 inch square tubing to reinforce it. Unfortunately this didn't leave the best surface for cooking and such. I was thinking of using some kind of thin wood as a table top that I could permanently mount to the tailgate but I don't know if there is anything available that would hold up to water and general outdoor use.
Can you still get teak? I know they use this a lot on boats. What about good sealing products?
waterweber
You could use teak but it is expensive and to get the best results to need to coat it with Tung oil that can be pretty nasty stuff (explosive).
I would go with thin Mahogany plywood, maybe 1/4" to 1/2" depending on how much support you have. You should be able to get a sheet of that for $25 bucks or so. I would stain it with some gel stain to get a little UV protection and then coat it with spar varnish. You other option is to use some redwood fence planks. They are pretty resistant the the weather but will turn gray over time.
NorthernWoodsman
Adventurer/tinkerer
You can still get teak, but it's expensive. If you nose around boatyards you might find some scraps for cheap though. You can also look around at thrift stores and find old cutting boards, which are sometimes teak. Collect a few of those, cut them up to the right shape and size and voila, a good cooking surface/cutting board all in one!
You don't need to use Tung oil with teak either. Sailors in the south pacific would use limes. Yep, that's right, limes. They're what was available and they have a natural oil in them that protects the wood. However, a lot of sailors never treat their teak and prefer to let it turn grey, but that's because it has more grip for walking on.
Another good option might be finding a hardwood plywood and cutting some thin strips of solid wood to cover the edges of the plywood which is a weak point where water will enter the grain and ruin the wood. You could always cover this with a water-based polyurethane. But, then you couldn't use it as a cutting board.
The Adam Blaster
"Liberate" some pre-treated fence boards from your neighbour's fence? lol
Seriously, you might try that stuff, you won't need much to cover the tailgate, and it will last a long time.
labbe66
Have you thought about using plastic? Something like the plastic cutting boards you can buy? I prefer this to wood for a cooking surface since it is less porous and easier to clean. McMaster-Carr has a lot of choices in material, sizes, and thicknesses. Another option would be to pick some pieces up at a thrift store/garage sale and piece something together.
Play around with the options here (http://www.mcmaster.com/#plastics/=6vg731) and I am sure you will find something.
DrMoab
I've actually thought about the plastic and aluminum and I might go this route. I'm just thinking a piece of wood would look nice and might have a little better "feel" to it than something harder.
Thanks for all the ideas guys.
articulate
Sure, wood will look quite nice. Teak isn't the only critter that'll handle the job, though. As long as you protect the wood appropriately, nearly any hardwood will do the trick. Teak has a high concentration of naturally ocurring oil, which helps it shed water. Anyway, if you use a hardwood I suggest a penetrating oil to shed water Deft makes an "exterior" oil that's very good -- Tung oil, by the way, is not "explosive" as stated above but the solvents for it are flammable. The downside to hardwood is you'll have to maintain it a couple times a year to keep it looking good. Sun and water are hard on wood.
For that reason, I'd be looking at aluminum or HDPE (like used on some synthetic cutting boards).
articulate
Well, something comes in wood grain that will hold up to the outdoors.
Just ask Clark Griswold. Is your trailer pea green?
attachment.php
flipstick
