White 1995 Land Rover Discovery Low Miles - $2500
KlausVanWinkle
http://losangeles.craigslist.org/sgv/cto/5543856344.html
For sale is my friend's 1995 Land Rover Discovery. This is an automatic 7 seater with both jumps seats still installed. It has 115,xxx miles on it with a clean title. I personally helped with a lot of the maintenance.
This truck would make a great platform for anyone looking for a cool and cheap off road or overland rig. Tons of maintenance and preventive work done.
I have nearly $3000 just in upgrades, plus nearly $2000 in maintenance and parts.
Price: $2500 firm
Upgrades:
-Front Skid Plate
-Front Diff Cover (the larger bolt on one, not the smaller one that just clamps on)
-Steel rock sliders with hi lift jack points
-T-Maxx Dual Battery setup. (fyi- washer fluid reservoir removed for this)
-HD fan clutch and brand new fan (never had overheating issues, but better safe than sorry)
-rear shelf set up (great for keeping organized can easily be removed as well, no permanent mods for this)
-Stainless Steel Extended Brake Lines
-32in (265/75r16) Summit Mud Hog MT Tires
-Terrafirma 2 inch suspension lift
-Coil spring retainers and relocation cones
-Terra firma HD steering dampener
-Ham Radio antenna installed
-Replaced old coolant reservoir that is prone to cracking with the newer clear one
-Replaced alternator March '15
-Replaced Spark Plugs and kingsborne 8mm wires March '15
-New oem master cylinder '14
-Upgraded to inline replaceable fuel filter (From Atlantic British)
-Dash curl fix kit (needs to be installed)
Maintenance:
-Regular oil changes (never more than 2000 miles without an oil change since I've owned it)
-Fresh fluids in diffs (a little over 2,500 miles on current fluids)
-Replaced gaskets and filler hose for fuel tank Dec. '13
-Replaced fuel pump Oct. '13
-The previous owner replaced the radiator and I had the coolant system flushed, serviced and tested in May '15.
-New thermostat installed May '15
-previous owner claimed to have the head gasket done before I bought, but no proof (he was a land rover tech so I believe him and I never had any issues.)
-Brake flush and check in May '15
-Fresh drive belt
-New O2 sensors
-New Catalytic converters Nov.'13
-New drive shaft coupler '14
Extra parts I have laying around I will include:
-Brand new head gasket set with bolts
-some random Hella lights
-Lots of spare odds and ends.
-Any LR specific tools I may have (will need to check around to see if there are any)
-Spare brake light switch
-spare bulbs etc
-spare hoses
-trailer hitch recovery point
Jonny Adventures
