To be honest, you can run transmission fluid through the intake as well. (vacuum line) But it smokes out so bad, it WILL blind other drivers if they are behind you. :Wow1: It's an old mechanic's prank to slip a little black can under one of you co-workers intakes and hook a vacuum line into it. Not only is it hilarious, but it does actually clean the intake. I would trust seafoam a little better for most applications though.
