Wildernest for Small Truck, $800 in Durango Colorado
Sock Puppet
Not mine, no affiliation, etc...
http://farmington.craigslist.org/rvs/4563851497.html
Works great, it's old so it shows some wear. I have had this Wildernest for 10 years (bought it used) and it came off a Nissan pick up and was painted the same color as the Nissan. It certainly could use painting to match the color of your truck. Am selling it because I bought a slide-in pop-up camper. It weighs approximately 300 pounds. I have the owners manual also. I had a new rear window installed by an ASE certified mechanic two years ago. The rear shell window life cylinders/lift arms/lift supports, whatever you want to call them, are not the originals since I had the new window put in. The originals stretched farther up so the window was more at an angle (see the photo with the kayak on top of my truck), the current lifts do not allow the window to go up that high, the window is now more level with the shell (see the photo with the snow capped mountains in the background). I was going to change the lifts out, but I'm short so it wasn't really a necessity for me. There is some fiberglass separation in the interior above the rear window, I never got around to repairing it with a fiberglass repair kit from the hardware store. Tent is in good condition, a little stained due from the poles rubbing against it over the years (this is common with Wildernests I have heard), and usage. The screens for the side windows have been removed so the dogs could stick their heads out, bark at other dogs, and drool down the exterior of the truck bed - you know how dogs are. I have the screens and the rubber tubing to reinstall them. It has a pass-through window in the front. The bed has the 3" foam mattress with a washable cover. What it doesn't have are the small posts that keep the tent windows at the front and back away from the tent to prevent rain entering. I always just zipped them up whenever it rained hard. The bed of the Wildernest will support 1000 pounds - so no need to skimp on the bacon for breakfast.
** Cash only, no checks, certified or otherwise.** Thanks.
RangerXLT
Ugh, if only. I wish I didn't just get out of the Navy or I'd go buy that tomorrow.
DanoWall
