Fitting is one thing, working is another. The short fire stick antennas are not designed for the springs. The springs are for the 102" whips adding 6" spring for a resonant 108" antenna. If you put a spring under a fire stick you just make the antenna 6" longer and most likely shifted the resonance point out of the band. If you happen to have a antenna with a tunable tip then maybe, but otherwise no.
