Herbie
Rendezvous Conspirator
Hiya experts. I'm at a spot where my experience and electrical theory meets my lack of experience in the realities of fancy AGM battery charging. I'm a bit worried that I'm setting myself up for less-than-optimal charging with my current setup.
For a couple of years now I've had the T-Maxx dual battery setup. Sears Platinum AGM batteries for both starting and house use. Group 34M deep cycle for the house battery, and Group 34 starting battery.
The T-Maxx has the usual feature of monitoring voltage on the battery terminals, then closing a solenoid (after a delay) to bridge them when it senses a charging voltage. This happens both on the alternator and with a charger connected. After about a year the cheap solenoid that came with the kit failed. I got a bit nervous that it was partly due to the solenoid being engaged for VERY long periods if my van was plugged into a charger for weeks at a time while parked. Also, as the charger would do its "thing", the solenoid would periodically open and close as the "maintenance" charge dropped below the threshold the T-Maxx uses.
This is question #1 - I've since replaced the solenoid with a proper Cole Hersee 200A continuous duty unit. Should I worry about the impact this VERY long activation and the periodic cycling, or just chalk up my previous failure to cheap components and rest easy now that I've got a quality solenoid?
After recently installing my solar setup, I realize now that the connection behavior also happens if the charging voltage is applied to the Aux (house) battery. I have a 1st-gen Morningstar SS-6 connected to the house battery, and it too will cause the T-Maxx system to periodically connect then disconnect the starting battery.
This is question #2 - I'm worried that the charger may not be able to do a proper full charge if it's seeing a changing "load" because the second battery is connected then disconnected frequently.
I'm less worried about "in the field" performance, since just bulk charge during the daylight hours will already be a huge boon to my system, but I'm concerned that I may be shortening battery life or at least wasting possible capacity when the van is parked for long periods of time.
This is question #3 - Should I add a manual switch to override the T-Maxx behavior and either (a) force the solenoid to stay closed when parked (thus presenting a constant battery load to the charger(s)) or (b) force the solenoid to stay open and "divorce" the charging systems when parked for long periods? This will mean going back to manually plugging in the house battery to a charger and letting the solar charger act on the house battery alone, but ok, fine.
Or am I worrying about nothing?
Thanks!
Thanks!
