Will these tires fit my montero?
swiftstar
I own a 1998 Mitsubishi Montero that I drive offroad, and I believe it's due for new tires. I'm currently running 31/10.5 on my stock 15 by 6 wheels, and I was curious on whether you all think I could fit 32/11.5 tires on these stock wheels without any rubbing or other problems? There seems to be a lot of space with my current size tires, so I was thinking bigger tires but I can't afford new wheels, and I've heard of people putting the 32/11.5 size tires on stock rims but I wanted to check myself. Y'alls advice would really help!
raysobi
I think I saw it somewhere in Mitsu thread that you can run up to 33 with stock wheels with no rub. I got 33 on but I did a torsion lift, no issues.
Sent from my SAMSUNG-SM-G935A using Tapatalk
swiftstar
That's awesome, do you happen to remember where you found that? And I was thinking about doing a torsion lift, but I wasn't sure if it would have a bad effect on the stiffness of the ride. And if I do should I have my truck aligned also?
jeep-N-montero
There are more than a dozen threads on here about what fits without a lift, please take a few minutes to utilize the search function or google and do a bit of reading.
Swank Force One
OP they will fit.
Now when someone googles maybe they'll get this thread instead of a million threads with no information and JNM posting to google.
PacS14
I got a 1999 with 33" KO2 no torsion, no lift, no rub. Unless your suspension is in dire need of repair/replacement I would not worry about fitment, and in that case replacing all the suspension components wouod be my priority instead of tires.
I did replace my shocks because the stock ones were completely blown, they (33" tires) still did not rub anywhere. Good luck!
