Wiper blades
p nut
butter
Thanks for the info. I'll check out Silblades, Goodyear, and that mega-blade (in electric blue).
rayra
Bosch ICON...treat with 303 when needed, but typically just replace them once they are at that point. I tend to replace mine every fall regardless because nothing sucks more than crappy blades in the winter.
Pretty much this and I actually have the Bosch replacements on my Suburban. Same for replacing tires, too. I might stretch a set thru the spring / summer, but if I'm needing new I get them for sure before winter.
rayra
Yep, a wiper change used to be $5-6 for a pair of blade inserts. Now it's $30-40 to change both heads. Damned scam.
Then again, at one point a new Ford cost $1,500.00
I replace the blades with Bosch (the articulated kind, not the single blade deal) twice a year.
What are these silblades you guys are talking about? Where do you get them?
Clemtiger84
