Wired Wagon Fuse and Relay panel
ghfaris
I bought this about 6 mos ago from Erik at Wired Wagon for a project that went another direction.
It is Config C, or switched 12 volts relay control. In other words, your switches will supply 12 volts to the relay coil when you turn the switch on. With this large relay panel, you will have 10 switched circuits for higher power devices and 10 nonswitched fused circuits for lower power devices.
$225 shipped.
