Wiring CB to fuse box/cigarette lighter
PhulesAU
CB's are cheap, you need the cleanest power and best tuned antenna set-up you can do get. Not the most expensive , mind you.
Schattenjager
I'm using a standard 12v cig plug for mine. Makes for an easy upgrade in the future or if the rigs electricals take a poop I can plug it into my Xantrex.
MotoDave
I ran mine temporarily off a cigarette lighter adapter, and it worked fine. I do plan to wire it through the fuse panel eventually, just needed a quick fix to get going.
SilverBullet
I have tapped the lighter and the fuse box both. In one of my old vehicles, I even had a spare slot, so I wired it and had a fused connection on the switch.
xander69
