Wiring for multiple accessories
Skinhyfish
I have seen a few things on here and read a little. Would love some guidance on how you guys are attaching multiple lights, compressors and other accessories to the battery. You have a separate panel that connects to battery? or attaching each one.. I know a lot about other stuff, but a rookie on electronic stuff. Curious what you all recommend or do for your setup.
Thanks Zach
LMarshall73
I made my own relay/distribution center from a Blue Sea fuse block and an aluminum door kickplate from Home Depot:
Adventurous
My first incarnation of an auxiliary electrical system utilized a Blue Sea 12-circuit fuse block. I moved away from that design because I didn't like having to find accommodations for a handful of separate relays. So I am using a Bussman block similar to the fellas above. It's small and everything stays tidy and centralized. That's what I would suggest.
Clemtiger84
