I'm getting ready to wire up some auxilary lights and a few other odds and ends and I'm curious where people are ordering their supplies from. I need wire, conectors, aux fuse blocks, relays ect. Any good online vendors I should be checking out?
I solder everything. I pull the screws from terminal strips and solder every wire down. Plastic aux light relays need a delicate touch and a high power iron for less dwell time.
Soldered connections rarely fail. If you do use connectors. Use dielectric grease on the wire before crimping. And also spray paint your aux relays and terminal strips down with Napa Battery and Ignition Sealant. Will help prevent corrosion.
Amain hobbies for flux, solder, and soldering stations. Weller 80w pencil for simple less sensitive wire connection jobs. 3m electrical tape and shrink. I do have a hitch with an aux backup light. I used a Deans ultra plug for that when I remove the hitch. LOLz.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
