Wiring up lights help
jhill15
I want to add a light bar to the front of my rig, only i'm not sure I will like a bar as opposed to 2 lights. Here is the bar I am gonna get.
"Not the best, but for the money worth a shot"
TMH 20'' Dual Row High Power 126w Cree Xb-d SMD LED Work Light Bar 13000 Lumens https://www.amazon.com/dp/B00KQXKG46/ref=cm_sw_r_awd_RWSGvbH29P3NZ
So my question is can I use a dual lead wiring harness that Is made to hook up 2 lights "just in case i wanna switch to 2 lights" or can I only use a 1 lead harness that is made for a light bar? If i can use a dual lead harness how do I wire the bar up? Do I just use one of the leads and leave the other unhooked or do I run both leads to the light bar?
Thanks in advance!
GregSplett
You tube installing light bars and you will find a ton of info put out both private and by the manufacturer.
The harness that came with your light is probably engineered for just their one light.
If you run two just ,leave one capped off in case you change your mind.If it is coming off one switch it will not mater which one .
jhill15
Sweet, thats kind of what i thought but i figured i better seek some advice before hand.
thanks Greg!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Clemtiger84
