Worldwide tire sizes for 15" rim?
BlurpleXJ
Hello ladies and gents. I lurk here often, post here little, but after a lot of searching I really haven't found a satisfactory answer to my question. Which is basically, is there going to be a significant difference between sizes trying to find tires worldwide for my 15" steelies? I'm looking in the 31" to 33" range, and I don't want to set myself up for failure when and if I get to take my Jeep on some overlanding outside the US.
Basically I currently run 31x10.5 tires on 15" steelies with 4" backspacing on my XJ with a 3" lift, and I'm really considering running larger tires when I swap to an OME suspension. I've read the many benefits of skinnier tires, but they're somewhat hard to find even in the US. Am I going to be able to find 33x10.50 tires worldwide? Will 32x11.50 or 33x12.50 be any better? Or should I bite the bullet and fork over cash for 16" steelies and run metric sizes? Hoping some folks with experience roaming other continents can weigh in. I will probably tackle a South America trip first, but I would be happy to learn more about any continent's tire availability. Thanks.
colodak
you may find them, but not as that size, but rather as their P metric equivalent. 31x10.50 is typically a 235/75 15.
rxinhed
Dirt Guy
31 would be a 265/70-15. A 235/75-15 is only 28 inches tall (approximately).
If you're world traveling, why not switch to a 16" like a 235/85-16? Or a 17"?
BlurpleXJ
I guess my question boils down to, can I find US LT sized tires outside of the US and Europe? If not, what is the most common metric size to run on a 16" wheel? I'm trying to avoid the metrics since they are largely load range E - doesn't really suit my XJ. But, if trying to find US sizes in the boonies will be a wild goose chase I'll settle for metrics...what size would you recommend?
onemanarmy
Are the 235/85/16 more common than 15 in tires all over the world? You recommend he switch wheels....are 16 and 17 in wheels more common in south america and Africa?
dhuss
