Planned on using this after installing my CB, but decided on something different. I installed it, then removed it the same day. Basically brand new. Asking $25 shipped to CONUS. Firestik description below:
The "Match-Maker" is the perfect accessory for people who want to use their standard ground plane dependent Firestik CB antenna for CB and AM/FM radio. Although there are some devices that claim you can use your AM/FM antenna for CB, be forewarned that your CB performance will be, at best, very poor.
The AR-1A does not allow you to use your AM/FM antenna for CB. Unlike the receive only antenna needed by the AM/FM radio, a CB needs its antenna to be resonant within the CB band. Tuners that allow the AM/FM antenna to be used for CB bleed off power to keep the CB's output circuits from literally burning out. If you only want one antenna, then the only wise choice is to use a CB antenna and the Match-Maker. Installation is easy too! Simply disconnect the antenna coax from the CB and screw it to the Match-Maker. Then, screw the Match-Makers PL-259 lead to the CB and put the pin-plug into the AM/FM radio's antenna input socket. Both coaxial leads are 18" (46cm)long. The Match-Maker has dual tuning coils and the tool and instructions needed to optimize the performance of both the CB and the AM/FM radio. The maximum input power rating of the AR-1A is 30 watts.
