saburai
Hi Gang!
After a long hard search for a larger gas tank for my '99 I've not been able to find any thing suitable.
I'm thinking I may install a marine below deck poly tank inside my XJ,
I found this one:
http://www.wmjmarine.com/moe-32518.html
It's 18 gallons and measures 36.5"Lx18.25"Wx7.25"H. They also have one that is 10" longer and holds 25 gallons.
It would be installed under a rear cargo deck with venting to the outside via the stock filler. I would plumb it to have a separate fill incorporated in to the rear most space just below the cargo deck. I would use a transfer pump to fil the main tank.
I could use a bit of help!
My XJ is parked about 60 miles away so I can't pull any measurements. Anyone know what the length of the cargo area is both with the rear seat up as well as down?
Comments thoughts and suggestions are most welcome!
I found this one:
