XJ CPS removal
alosix
Last time I did this I pulled the x-member and lowered the tranny as far as I could get it to go. Then with a combination of 1/2 of the extensions and ujoints I had in my tool box I managed to get to it.
Its tough. I think the XJ one is the hardest to get to that I've had to do on a Jeep.
Jason
BIGdaddy
How do you get to the %@#&%^^$ top bolt? I have spent 3 hours under the thing and I may have touched it once HELP!!!!!!!!
Weasel:confused:
thats the one on the tranny housing, right? two bolts?
if its the one I'm thinking of, you're not alone in your salty sailor talk. Its a tough one.
Lowering the tranny is a good idea.
I'd also log onto Naxja.org and see what others have done...
-B
Root Moose
Extensions and u-joints. Then you'll slap yourself on the forehead for wasting all that time earlier today. ;)
alosix
If the last one I did wasn't soo covered in oil from leaking all the time I would have just broken out the plasma cutter and made me an access hole in the firewall.
But alas, I've already set that XJ on fire 3-4 times welding on it, figured i'd be pushing my luck :)
Jason
Goldenbora
