Xterra - Shocks help nose dive?
jktowhere
So a 04 Xterra is my DD. I am not all that happy with the ride right now. I'm at 101k on it, so I am thinking the shocks and steering stabilizer need to or could stand to be replaced.
The issue, and I know this happens with xterra's because I can see other hit the brake and have the issue, are nose diving when braking, the steering wondering and the ride just seems really all over the place. Am I right thinking the shocks will help because really, of all the suv's I have owned, this feels the worst and almost uncomfortable the way it nose dives. If so what do I replace the stock with? It's all stock minus a front bumper.
davidshourd
new shocks and maybe give your torsion bars a couple cranks to stiff things up a bit. dont forget an aligntment when you are done. the 04' back models suffer from some front end steering issues. they tend to wear a little faster than they should and results are a "Squirly" or loose steering.
jktowhere
Well, lets start with the shocks, thanks guys. I hope this will work because I am losing faith in this truck and I think its just me being quick to panic. What are the part numbers?
mortonm
Take a look at my build thread. Recent post has some pictures of my install along with part numbers
FYI the HD rears require removal of the rear sway bar but in these xterras they don't do much and its removal is not noticeable on road and provides better suspension articulation off.
http://www.expeditionportal.com/forum/threads/79780-Mortonm-s-2001-Xterra-Build
Silver dude
Xplorer
I'd recommend stiffer torsion bars. especially if you have a front bumper. Otherwise the front end can seem wallowy and soft with the additional weight. I'd start at the shocks though. Dollar per dollar they make the biggest difference in ride quality.
