uriedog
metal melter
For sale Yaesu FT8900R quad band transceiver. cross band repeater function. great for mobile, or base station
$550.00 CAD + shipping unless you are near Calgary
The FT-8900R is a ruggedly built, high quality Quad Band FM transceiver providing 50 Watts of power output on the 29/50/144 MHz Amateur bands,
and 35 Watts on the 430 MHz band. It includes leading-edge features like cross-band repeat, dual receive, VHF-UHF Full Duplex capability, and over 800 memory channels.
And its 10-meter FM coverage brings the possibility of world-wide FM DX-ing to you on your drive in to work!
Cross band repeat lets you get out of your vehicle and use you truck radio as a repeater. Gives you a major signal boost!
Comes with
original box
manual
YSK-8900 Separation kit
Mounting bracket
Diamond CR8900A quad band antenna.
factory microphone
The radio is in excellent condition, has had very little use. Non smoker. Bought it last summer less then one year old
Already programmed with all of the local Calgary, and BC repeaters
Quad Band Mobile
28-30Mhz Rx/Tx
50-54Mhz Rx/Tx
108-180MHz Rx
137-174MHz Tx
320-480Mhz Rx
420-470MHz Tx
700-823.9875MHz Rx
849.0125-868.9875MHz Rx
894.0125-913.9875MHz Rx
939.2125-958.9875MHz Rx
984.2125-985MHz RxFM
data packet 1200 baud
Comes with
original box
manual
Mounting bracket
factory microphone
Quad Band Mobile
28-30Mhz Rx/Tx
50-54Mhz Rx/Tx
108-180MHz Rx
137-174MHz Tx
320-480Mhz Rx
420-470MHz Tx
700-823.9875MHz Rx
