Yakima gutter mounts, 2nd Gen: What size?
vgreen
Putting the G in RGB
Hey guys,
I want to remove the fairly useless stock rack all together and get Yakima gutter mounts. I already have Yakima crossbars on the truck, mounted to the stock rack. Beside being a little weak, this setup is tall. I would like the cross bars to be as close to the roof as possible. Yakima only offers two sizes, the standard 1A and the Highrise, a 1A with a 3 1/2in extension. I've measured and I believe the standard will fit, but I thought I would double check to see if anyone on here has run a similar setup.
EDIT: Ok, just found where you can enter your vehicle in the Yakima website (duh) and if I enter "naked roof" for factory options, meaning no factory rack, the standard 1A came up.
http://yakima.com/shop/baserack/1a-raingutter#TABSANCHOR
So kinda a useless post so far, but I have a second question. Has anyone ever removed the factory rack? I am afraid I have to remove the headliner, but I don't really want to!
I am ordering these Friday, so in a couple weeks I will update with photos of how close they get the bars to the roof.
Clem
I just did this.
1A towers fit and the bars are close to the roof, but I haven't measured. I have now measured the distance from roof to crossbar...about 1 and 1/4 inches in the front above B pillar and only about a 1/2 inch at the rear about mid way through sliding rear windows (it was getting dark). This is in the middle of the bar and there is a bit of a crown so there is a greater distance closer to the towers, but not much. I did not need to remove the head liner, just a large Phillips head screwdriver.
Check out these posts...
Post #16...http://www.expeditionportal.com/for...et-Size-on-a-Gen-II-5-Is-this-too-small/page2
or
Post #127...http://www.expeditionportal.com/forum/threads/24947-My-latest-mitsu-build-up/page13
HTH,
Clem
vgreen
Thanks guys for the quick replies. Thanks for taking the time to measure Clem, that sounds about perfect. And those were very helpful posts thanks so much!
iStan814
