madmaths
Hi! I have some question about charging a agm battery I did some google research and from what I found my agm battery should be charge at 14.4. ( please correct me if this is wrong)
my question : I have a 100w solard panel and this charge controler http://www.hqsolarpower.com/30-Amp-PWM-Charge-Controller-with-LCD-Display-p/hqst-ctrl-pwm30lcd.htm
this charge controller dont have agm setup so I think the best setup whit he best voltage value is the sealed setup, make sense? ( please refer to the pic)
second question the controller have 2 setting : the over discharge voltage setting ( not sure at what valut I should set it ) and I have over discharge return voltage , what is this for??
thanks a lot!!
thanks a lot!!
