Zodi instant hot shower propane powered
peekay
http://www.amazon.com/ZODI-Outback-Gear-Travel-Shower/dp/B000X4IAMS/ref=sr_1_1?ie=UTF8&qid=1400136121&sr=8-1&keywords=zodi+hot+shower
Runs off the little Coleman propane bottle
Very low usage, maybe used 4 times at most, then has been in storage for a few years.
Pump is broken. Won't turn on. Not sure if a loose wire or something. You can either try to fix it, get a new Zodi pump here, or stick in some other type of pump. http://www.amazon.com/Outback-Gear-Battery-Powered-Shower/dp/B002L9A4BI/ref=pd_sim_sg_1?ie=UTF8&refRID=1DJ8ZFR94ES663D0YVQB
$60, prefer local pick up.
Pic is here: https://www.dropbox.com/s/5s6z83kqh1eywks/20140514_221351.jpg
I work in Riverside, CA, and live in Hacienda Heights.
310-254-5585
Lucky j
i have one of these.
It is very nice. Just a tip, pre heat your water in the bucket be recirculating the water through the heater until you reach the desired water temperature, then turn the heater off and just use the pump (on/off) as you need the water for to shower. Safe on water and avoid being burn.
When you turn the pump off, the water keep on heating to boiling point!
But IMO, a good afordable shower waer heater! Can us it to heat any washing water, as long as it is clean!
