Zr2 rear seat removal, cabinet and storage install?
Want to remove rear seat in my zr2 and build a flat platform/storage system to house inverter , arb Linx controller, other electronic access points(usb / 120v) for a work station type system.
Has anyone else removed the rear seat and done the same ?
If so could you provide pics/links looking for help and ideas.
Thanks everyone
dmwhiteman
Just pulled the rear seats out of my frontier and put this platform in. Going to mount my inverter underneath and run an extension cord to the front seat
Sent from my SM-G955U using Tapatalk
Are you gonna make it permanent And cover it in carpet ? Or make it easy to remove ?
dmwhiteman
I put a piece of heavy duty rubber from tractor supply over it. Going to cover the edges with some gorilla tape so its easy to repair when the dog tears it up. To remove it I just fold the front seats as far forward as the will go and tilt from the front to the rear and pull it straight out. Its the perfect height for my wife and I to fit our REI duffle bags on one side and our recovery gear on the other.
YaRiteZ71
