Post Pic's of your Jeep
JeffRRC
Thanks, so does he. At first he liked the stinger but tired of it so we cut it off and mounted a set of Piaa fogs inside. Eventually he wants to mount a winch so we will have to modify it a bit more to make that work.
BManga
Hey from GA. Here is our junk. Yes his and hers rock crawlers. :)
My XJ:
Wife's TJ after building cage and hood/stinger/bumper:
Loaded and ready for ride. Tow rig is a Crew Cab, long bed, dually Dodge 3500 Laramie.
cigarluvr
Thanks, I am going to do about the same in the rear. I just wanted to see more so maybe steal an idea or two. I have some plans already for the front, I am going to run through cad to see how strong it will be in aluminum.
EDIT: It looks very tight and small which is one of the goals, so I am hoping to see more. I like what I can see so far, very well done.
Thanks for the kudos. I would be willing to bet that it would be plenty strong in Aluminium. The trick is to mount it right. I am almost certain that I over engineered the mounting brackets. FWIW, the front bumper without the winch came in at 85lbs (3/16 majority w/ 1/4" winch plate) and the rear at about 95lbs (all 3/16").
mikeg1713
Where can I get a set of these, lights and all? I looked on their website, but they don't have these. I'm very interested.
The corners are the builders corners. The lights are Grote lamps. You can find them on eBay or get them from www.isee-systems.com. Theyre off the MRap and other mil trucks. You'll need to fab the corners to put them on as I did or order the adaptors from isee-systems.
Here is a pics of AEV's 6.4 Hemi next to my 12 Jk. You can see their corners with standard lamps and my MRap lamps with their armor.
Thanks,
mikeg1713
They are H1 tailights. Custom fit. My buddy did the same on his TJ. Very cool.
H1 lamps are different. They look just like Jk or TJ lights. M998 lamps are very close but they used light bulbs not LEDs. Truck lite and grote make lights like mine. I've found grote is a better company. But that's just my opinion. You will also need back up lamps. Isee-systems has those also. They are single high Clarence LEDs. 3/4 inch Di hole needs to be drilled to hold them.
SquareLJ
Do you have any more pictures of how it's mounted or a write up?
Houie
