Builders.....FRP panel?
lilgription
For anyone who has used or seen any teardrops type campers with FRP, will FRP hold up to the weather and elements assuming that it will be glued to a luan or other type of plywood for an exterior finish..
Aspen Trails Trailers
Supporting Sponsor
I have never seen one built with it that I am aware of.
But if it is sealed all the way around, it should be fine, if it is strong enought to with stand hits, I would guess it would work.
Hope that helps with your questions.
lilgription
Its supposed to be good stuff, when applied with a backer such as luan . I just wonder if its Uv treated enough to withstand outdoors like the type big box sores carry.. thanks Bob
Supporting Sponsor
I use the same stuff that all the major manufacturers use, I have mine made with two luan sheets and one fiberglass. The industry standard is one sheet luan. It is very strong with two sheet of luan. A little harder to work with, but makes the trailer better I think.
Titanpat57
Pat I have a few? For ya. What did you seal the seams and corners with? I overlapped, starting at the bottom and working my way up(the nose was waaaaay more intricate than I had figured) and I used spray contact adhesive, full bond. At the seam I used a Norton fast drying epoxy, 5 minute if I recall correctly. First I sprayed both sides, the plywood and then the FRP, , then taped off where needed. Next I applied the epoxy at the seams..and for the record, once the contact adhesive hits it's "game over" anyway..a one shot deal so to speak. I left the the edges protrude about a 1/4" all the way around...then trimmed as close as I could with a laminate router (the epoxy after a 1/2 hour was like hard plastic) , and belt sanded with fine after that.Did you use rattle can paint - rolled it on - or use it a spray gun? Once the sheets were up I used an orbital sander with 120 grit and "knocked it down a bit"...then I wiped it clean, primed it Rustoleum Plastic Primer, and shot it with a few coats of Rustoleum Silver, oil based. The finish was applied with a HVLP machine...I pretty much spray everything with it. Did you get the sheets from a big box store, bathroom grade stuff? Yep...got it at the Depot. How is the paint holding up now? The paint still looks good, but she will get a coat in few weeks to freshen her up a bit...but no failure in any spots. The only thing that is troblesome is the seams. Since the two materials, plywood and fiberglass, expand at different rates, the seams have developed hair line cracks. I'll be designing a moulding to cover them, just to ensure they stay water tight. Traveling down an interstate in a driving rain is a true test for any seam. Thanks for any info
and your welcome...good luck on your project.
Pat
