Considering a Yaesu FT-897D, any input?
waltel
Yaseau 857
For my firts entry into Ham I am close to a decision between 857D and 897D having passed over 817D for too little power.
What is the best option for an antenna and can I assume a beginner wants an antenna with a tuner?
Anything else I should buy with radio to get started listening. Will get Technician lic in a month or so...
Thanks
Waltel
Corey
OverCamping Specialist
Get a duplexer and the Yaesu ATAS 120 antenna like I have.
It is made for these units.
762X39
The radio is a great choice and beginner or not, an antenna tuner is a good idea, needed in fact.Enjoy!:coffee:
1911
The 857 and the 897 are electronically identical; one is packaged more for mobile use and the other more for base station use but plenty of folks use either one for both of those uses. Great all-band radios in any event.
You'll need more than one antenna to fully utilize either of those radios; at the very least you'll want a dual-band 2m/70cm antenna for those bands and an adjustable multi-band antenna for HF like a Tarheel or the ATAS-120, but you could save some money by having a few ham sticks for different HF bands and just change them out on the same mount as needed. Tuners are handy for adjustable multi-band HF antennas but not required for fixed-length antennas that you can tune once when you install them.
If you're set on having a tuner, then the Kenwood TS-480SAT radio is another option that has a built-in tuner. I have this radio and like it a lot. However, it is only an HF radio so you would need a second 2m radio for trail commo, APRS, etc.
Thanks
Waltel
I find the Nifty! mini-manuals to be a useful thing to carry with me instead of the entire manufacturer's instruction/operators manual for a given radio:
http://www.niftyaccessories.com/
Good luck on your test! Recommend that you study for and take the General Class test soon after you pass the Technician, while you still remember the basic stuff.
Also don't forget even with the Tech license there are plenty of freqs available to you. ARRL has a chart of them. I am going to start studying for the general too, but I'm not in any hurry as I can use all the bands my FT8900r operates on.
cruiserlarry
One Crazy FJ
I use the Yaesu FT857D / ATAS-120A combination in my FJ Cruiser, and have made contacts all over the world without issue. While some hams consider this a "compromise" system, they are amazed when I go head to head with larger units in the field - many times my FT 857D and ATAS 120A smoke the larger, more complex systems. I would choose the 857 over the 897, as the 857 has a better display and a much smaller, lighter footprint. The only advantage to the 897 is it's ability to work with internal battery packs - not a factor in a vehicle mounted situation.
gary in ohio
The ATS-120 is fine as long as your not planning a lot of 40/80m contacts.. If you do a lot of 40/80 work then look at a bigger screw drivers antenna or tuned whip system.
SP Jon M3
The ATAS-120 only goes down to 40m, it's not designed to operate on 80m. I also have to echo Larry's statement. I've been very happy with the 857/ATAS-120 combo. I've made contacts as far as Tazmania with this setup, even through the small pileup.
AA1PR
Disabled Explorer
I got burnt by yeasu's customer service/repair dept a while back
I would say look for an older Icom706MKIIG
I run an 706MKIIG with a LDG autotuner & a 12' whip, with it I can tune from 40m to 6m
xtatik
Thanks for sharing your opinion.
KevinMLee
Wannabe
So I have a quick question for you guys, I, too, am considering HF primarily for safety because of it's range. before I dive in, heres a bit of my background and why I'm looking for a solution.
I'm a photographer that needs to communicate with my assistants so I have iCOM commercial radios (the BC-100 from BearCom). These are analog UHF radios. They work great for what they are, but was considering the iCOM 6061 which is a commercial mobile. However, I haven't made the plunge yet and am considering... if all possible, a unit that does have HF and commercial UHF. This will cut down on dashboard real estate with one radio.
So my question is, if I invest in a Yaesu radio that does have HF/VHF/UHF, will I be able to program it to operate on commercial narrow band UHF frequencies/bands? or am I outta luck?
Thanks guys
