I Like that 4bt, something to keep in mind for when my tired 5.0 takes its final breath which I fear will be sooner then later. Was it a pretty straight forward swap fitment wise? Availability of parts?
I used the original hydraulic isolators that came with the engine then I modified the original engine brackets and had to make new frame brackets. Parts for the engine are not a problem, I got a lot of my stuff off Ebay. My engine came with a TH400 set up so I had to get the Ford trans adapter and flywheel. I used the original trans crossmember in the back. These old Fords are almost made to fit the 4BT. All the other stuff I did to the truck took most of the time.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
