unabashedpraise
I have a roof rack that I bought brand new a few years ago for $5. It's not the most 'expo' rack out there and I think it looks kinda funny on my zj, but it's what I have so I will work with it. Due to the rack mounts and the roof rail height it sticks up higher than I would like, but I am going to use the space under it for storage of a camping table.
I have test fit a fairing made of cardboard to cut down on the howling and to hopefully help with weather and mpgs. As you can see in the pic, the front slopes quite a bit. This fairing is going to be pretty big and I will probably be making it out of plexi.
I will use some u bolts on each of the four corners to attach the slanted piece. I may have the u bolts sticking out of the top to use them for cargo attachment points. Or I may just use something to use as a spacer to lift the top of the plexi off the rack about 1" and use the rack for cargo attachment.
My question is how do I join the two pieces of the fairing? I was going to use a u bolt with some sort of flat extended piece to attach the vertical fairing to. But I was also thinking about making it so that the fairing could rotate up if I had something longer to fit under the rack. The vertical faring can not permanently extend too far forward as it would block the sunroof from going up.
I hope you guys can make sense of this post!
