gait
just a thought from recent experiences with FG,
atmospheric pressure at 1,100m (Bend, Or) is about 90kPa, which is about 10% lower than sea level (100 kPa). I don't know about relative humidity or ambient temperature at Bend. All three have the potential to effect turbo boost.
I don't know what conditions the engine specification relates to. I don't know how the control scheme compensates or over what range of atmospheric conditions.
I do know that at about 3,800m (about 65kPa) my FG engine malfunction light is on at some rpm and load conditions due to low turbo boost and at 5,000m (55kPa) more often. Unfortunately I don't know the boost measurements or at what level the ECU records a problem.
Without measurements its difficult for me to know but it appeared that fuller fuel tank with better fuel delivery, fuel filter, and clean air filter provided some improvement. I didn't attempt tuning the engine for higher altitude.
With two fuel tanks I know there is a minor niggling problem with delivery through the longer pipe from one tank that occasionally prevents running the tank to empty due to fuel starvation. A resolved related problem was a small air leak in the bowl of the water seperater. I replaced all pipes, one day I'll add an extra electrical lift pump.
Hopefully there may be some ideas in the above.
