Torsion bars
Inside the lift there are steel rods with hex cut ends that go into the rear brackets . they are relaxed when fully extended I'm told. They aid in the lifting capabilities. I took mine out My roof goes up with ease without them. I also have a Skamper 080s (for sale) and it goes up a little stiffer but no big deal. I was a little gun shy at first with the Skamper when my handle slipped ,now I just stay low when raising either roof.
My North stars roof frame is Lap jointed 1/2 " marine ply ( marine has more layers of ply) 1/2" ply doubled= 1" x 3 1/2" rips with staggered joints on roof edge and top there is a space between plywood on roofs flat surface and side surface to allow Aluminum to roll over ( Am I making sense). this 1 to 1 1/2 space was filled with foam.. There is very little wood in the field . the field is filled with 1" foam board glued to the Aluminum skin . the inside ceiling luan is glued to the foam.
Scraping the old broken foam of the aluminum was not difficult, but it was on there. The manufactures' glue had a green tint . I went with vinyl flooring glue I had lying around to glue foam to aluminum skin. The ply frame I used Liquid nail and stapled.
My rear brackets took a beating I managed to straighten them into working order . they also pulled on one side I went with new plywood on inside . cut my lifts an 1/2 " shorter and used 5200 marine caulk and large washers to seal. Thanks for the pic edit
