My LR3 lightweight storage platform build (UPDATED: actual dimensions on pg 4)
Crimond84
Really nice job.
I'm hoping to do something similar, although I'd planned on only using ply (mainly because of a lack of access to welding kit).
Has anyone had any experience in fixing a half width storage solution in though? I love how you've secured this using the tie down rings, but I'm planning on only have a half width box / drawer (I need access to the 6th seat) so I'm not entirely sure how to fix the unit in the middle of the car?
perkj
Really nice job.
No welding needed with my set up as all connectors just press in. For a single side platform frame you will need to come up with some type of bracket that you can anchor at some of the anchor points holding in the 7th seat
perkj
Push for connectors you say! I may to look into that.
Here is an example of the connectors:
...then you just press them into the 1" aluminum tubing with a rubber mallet. Go to www.eztube.com. Note that you need to purchase their tubing as it's got ridges inside it that bites into the connectors.
cannonball55
Love the storage solution, and the prices on eztube are not bad at all. I just might have to make something similar down the road. Question on the travall barrier mounting points, what do they attach to on the c pillars there? do you screw it into the plastic molding and i assume metal underneath?
perkj
its just pressed against the c-piller. From the pictures you will see that it levers on the side plastic shelving and then mounts into place with a j-hook attached to the lower drings. its a really simple mouting system and could some in and out in under a minute. Its very solid once in as well.
sunrisehiker
I have Travall for over two years now and it is a perfect product.
Does not require drilling into C pillar at all.It tightens up there with a combination of turning the knob on floor/ tie down point and adjustable leg that sits on the C pillar itself.
Ilatak
Any chance we can get a dimensions added to the first sketch for tubing length?
I like this solution a lot and I also just install Travall barrier today:)
Thanks in advance.
Quest4ADV
That looks fantastic.
That is exactly what I'd like to do with the XTerra. Drawer systems are nice and all, but adding 200+lbs right out of the gate doesn't exactly excite me....
Im local to you, any chance we could link up sometime so I can see in person? First round is on me....
Cheers.
-K
When you get yours done post some pics so I can do mine :)
Ilatak
Well, I've made the same thing and I must say I like it a lot. I do travel with the dog so, I fill like I've gain the space under, which otherwise was useless.
I am planing to make a metal mesh divider with a door for the dog, similar to LR original but obviously smaller now:)
perkj
Great job! Looks pretty damn close to mine. Sorry I didn't see your request for the dimensions.
I'll get them posted shortly for others that would like to duplicate.
aaronalden
i'm also looking to make a front-section for a sleeping platform like you mentioned. if you have already made measurements for that part of it that would be great to see as well.
ih8philly
Do you think I could get away with a 30in span between uprights with this material? How far are you guys going between vertical support?
abctrash
