Battery Usage Calculation
casejeep
I know this will seem pretty basic to a lot for you people. But I can not find the answer in terms I can understand.
How do I figure out how long I can run said electronic on my dual battery set up?
Also, let me run this by you guys. Run a live wire from the vehicle battery to a cut off switch. When the vehicle is on turn the switch on so the 2nd battery charges. Turn switch off when vehicle is off? Is this too simple to work? Am I missing some very fundamental electrical engineering?
Thanks
mm58
Without considering any variables, basically an 80 amp hour (A/hr) battery, fully charged and in good health, will power a one amp load for eighty hours. Or, a .5 amp load for 160 hrs; a 2 amp load for 40 hours, 8 amps for 10 hours, etc etc
DaveNay
Without considering any variables, basically an 80 amp hour (A/hr) battery will power a one amp load for eighty hours. Or, a .5 amp load for 160 hrs; a 2 amp load for 40 hours, 8 amps for 10 hours, etc etc
Also, for a deep-cycle battery, you should not use greater than 50% of the capacity. A standard "starter" battery on a vehicle isn't really suitable at all for a lengthy discharge (5%-10% of capacity?)
casejeep
How do watts factor into this?
mm58
Volts x Amps = watts.
Say you're running a 12v appliance that draws 5 amps. That's 60 watts of 'power'
dwh
Tail-End Charlie
Thanks
That would work. Keep in mind that it might take anywhere from 8 hours to 24 hours of drive time to fully recharge a 100 amp*hour battery that's halfway drained depending on your wire size, and how your truck's voltage regulator behaves.
croix
Watts divided by volts = amps.
A 120 watt device at 12V will draw 10 amps per hour.
An 80 A/hr battery would run that device for 4 hours (@ 50% reserve capacity)
Please keep in mind that this is a good starting point, but results may vary. Things like line loss, temperature, battery age, etc. will reduce the number of hours you actually get from a battery. If the loads you plan to use for the number of hours you plan to use them push the limits of the battery, you may consider stepping up to a battery with more amp-hours. Just my 2 cents.
-croix
croix
Thanks
Although this would technically work it could create significant problems. For example, batteries of different age will try to equalize when connected. This can degrade one or both batteries. Also - depending on which loads are run each battery you could end up draining both batteries if the switch is left in the wrong position. Personal opinion here... but a dual battery setup works better with a proper isolator to control when each is charged and prevents primary battery from being drained below starting voltage.
Hilldweller
SE Expedition Society
-croix
Plus this.
You've got a theoretical 100 ah battery in pretty good health with 95 actual ah available. A 40 watt appliance. The battery is charged to a nominal 13v to start.
Appliance, a fridge, duty cycles according to its thermostat ---- 40 watts divided by 13 volts. But the volts begin to drop and the amps rise. It's a logarithmic loss...
DaveNay
Plus this.
The OP is a beginner....throwing all these finer details at him is not going to help him grasp the fundamentals.
Hilldweller
Okay.
In other words, aim high. Have more amps than you think you'll need, drain your batteries as little as you can, & fill them back up as soon as you can. Formula for happy batteries.
DaveNay
Okay.
You did notice that I suggested he de-rate his battery by 50%? :iagree:
