daniel ruops
FOR SALE
EXPEDITION CAMPER
AATREC FM260-Advanced All Terrain Recreational Extreme Camper
Built by Darin Fink, Renaissance Universal Fabrication Inc.
Mileage- less than 60,000
Price: $150.000
Contact
Daniel Ruops
760-518-8687
danielruops@me.com
The 2007 FM260 Mitsubishi Fuso has a 6M6O engine and is the last model year of the highly regarded chassis with NO ULSD requirement. There is no catalyst, thermal reactor or urea injection thus any diesel fuel can be burned. The exhaust consists of a brake valve and muffler. Total length 25 feet.
CABIN
3 point pivot frame. RUF torsen- free subframe eliminates stress between chassis and cabin
Cabin length 17 feet
Espar diesel furnace
Force 10 stainless 4 burner range (thermocoupled for safety}
Dometic microwave oven
Queen sized bed with easy access additional storage beneath
Refrigerator
Second compressor chest style refrigerator/freezer
Adequate internal and external storage
98 gallons fresh water capacity contained within the cabin
LED lighting in cabin
Seitz windows with insect screens and blackout shades
Manual entry stairs
Nature's Head composting toilet
Stainless steel shower floor
Cherry hardwood cabinets
Gray water capacity 45 gallons
Water heater 6 gallons
Pass through to cab with pull down locking shutter
Rhino lining on roof
ENGINE
Mitsubishi 6M60 SOHC inter-cooled I-6 turbo-diesel
Cab tips forward for complete and adequate access to the engine
460 CID (7.5 liter)
Four valves per cylinder
Common-rail injection system
Ceramic-typed glow plugs for cold start assistance
243 HP @ 2600RPM
516 lb-ft @ 1400 RPM
12 Volt, 100 Amp alternator
ELECTRIC
7.5 kw diesel generator
2000 watt inverter
Four 130 watt solar panels
600 A/Hr AGM battery bank
Blue Sea Systems marine-grade color-coded electrical system
2KW pure sine wave MagnaSine Inverter
LCD TV, DVD
TRANSMISSION
Allison LCT 2400 automatic
5-speed
Electronic overdrive
26,000 GCWR
FRAME
Ladder/straight type
Section Modulus: 13.73 cubic inch
Yield Strength: 51,200 psi
Custom front bumper
Rear 2” receiver
FRONT AXLE
12,000 lbs.GAWR
Manually locking hubs
Double-Cardan steering joints
Single-reduction hypoid final drive, 6.50:1
REAR AXLE
RUF custom built Dana 22,000 lbs heavy walled axle
Extra heavy duty housing
Rear axle differential Lock
FOUR WHEEL DRIVE
Installed by Marmon Herrington
Heavy duty aluminum transfer case with constant mesh helical gears capable of 7,400 lb-ft input torque
BRAKES
Air over hydraulic control
Four wheel disc with ABS
Bosch calipers with 73mm dual pistons
Rated 34,000 lbs/axle
Air actuated exhaust brake
SUSPENSION
Front: Fuso Tapered Leaf
Rear: Fuso Laminated Leaf
TIRES
Bridgestone M711, 11R22.5
WHEELS
Accuride “22.5 x 8.25 forged aluminum
STEERING
Ball-nut type
Integrated hydraulic power booster
Tilt steering column
TURNING RADIUS
29 feet, curb to curb
FUEL CAPACITY
100 gallons (US) in 2x50 gallon factory side mount tanks
CHASSIS/CAB
Spacious “extended” cab
Passthrough from cabin to cab with security shutter
Dynamat installed for noise reduction
Heated mirrors
Air conditioning
Bostrom air ride seats
Rear-vision camera system
EXPEDITION CAMPER
Price: $150.000
Contact
Daniel Ruops
760-518-8687
danielruops@me.com
CABIN
Refrigerator
Manual entry stairs
ENGINE
460 CID (7.5 liter)
243 HP @ 2600RPM
ELECTRIC
2000 watt inverter
LCD TV, DVD
TRANSMISSION
5-speed
26,000 GCWR
FRAME
Custom front bumper
Rear 2” receiver
FRONT AXLE
12,000 lbs.GAWR
REAR AXLE
FOUR WHEEL DRIVE
BRAKES
SUSPENSION
TIRES
WHEELS
STEERING
Ball-nut type
TURNING RADIUS
FUEL CAPACITY
CHASSIS/CAB
Heated mirrors
Air conditioning
