Les's '01 XLS
ifixpc
Hi Guys!
Finally want to introduce myself.
I've been a silent reader for quite some time while researching and trying to figure out what I wan't to drive for fun.
I've been debating between FJ80 Landcruiser and a 3rd Gen Montero.
Finally one of my customer's helped me with this decision.
He was about to trade in his 2001 Montero XLS with 159K for a new car for $1700 and I grabbed it.
Picked it up late February, but it sat parked for a month until I got it serviced.
Here's how I got it:
I knew it was due for timing job (cam seals, timing belt, water pump and tensioners) as the belt has jumped and fortunately hasn't caused any severe damage.
Car had loud knocking noise when I looked at it and it turned out timing jumped by 4 teeth on crank, cams were still aligned.
I've also changed all fluids (oil, diff/transfer case oil, trans oil) and tried it out at The Cliffs in Marseilles, IL.
Trails were very muddy and even the easiest trail (#1) was in very bad shape. I got stuck in some deep mud and had to be winched out by some helpful guys in a wrangler.
Apparently the #1 trail is cleared and groomed now. I'll be going there tomorrow again.
Some pics from The Cliffs:
And a short vid:
What I learned after the first offroading trip is that I'm in desperate need of mud or good all terrain tires and a winch.
I might also be looking at a lift as I already lost some plastic trim pcs of the front bumper.
I've already met a guy who is willing to weld in a plate to hold a winch to the frame. I'll attempt a hidden winch project.
As for tires I'm debating between all terrain 235/85/16's or 265/75/16 mud terrains.
Some other things I've done to the car right now are just cosmetics:
Replaced all interior bulbs with LED bulbs (that includes the cluster).
Old radio had shut display. I've picked up a Sony unit with bluetooth phone support, microphone, pandora and some other goodies.
I've drilled a hole in the console to install the microphone.
At the same I've pulled out the clock and tray from upper center console and permanently installed a touchscreen 7" GPS unit that was just sitting around in my garage. It's a cheap cobra unit, but anything 7" would be a perfect fit. I hardwired it to the radio power signal cables and took the battery out of GPS so now it turns on/off together with the radio.
Tomorrow I'm heading out for the cliffs again.
Plan for next week is to order the winch and get the winch plate welded in.
I'm also working on repairing an Edgestar 63Qt fridge to get it installed in the back. Once I get it running my plan is to get it installed with a 100W solar panel and battery pack. Have way too many projects going to share full details at once.
Will try to keep you posted from time to time!
Thanks
Les
All your custom work looks great. I really like your gps install. I've always thought a full screen nav would look right at home mounted there!
jhill15
Welcome to the forum man! Man I really dig your gps mod! Look very well done. Where do you have power hooked in? Do you the 12v dc adapter going into the cig lighter underneath the climate control, or something else?
ifixpc
Second trip to The Cliffs
Today I took my wife along to get her hooked on my new hobby.
She loved it and we both came to the conclusion that we'll try to experiment new offroad parks.
Big plus is that we love camping with our kids and most of the off road parks I researched have camping sites close by.
As a result of today's trip I also received a "Green light" on a search for a cheap quad so we can both have fun at the same time.
We've had a lot of rain in the past few days which resulted in very muddy, rutted trails.
Many of which were inaccessible for us due to stock tires.
Right now my budget is going to be tight as the quad also came to play so I'll hunt craigslist for a used set that should be OK for a while.
My wife promised to get me a winch for my upcoming birthday ASAP. :wings:
Hopefully it will arrive by the end of next week.
I don't know what your experiences are with the winches sold on Ebay, but again...it's my first and most importantly inexpensive build for a fun weekender car that I'd be able to use daily.
Here's what I picked:
http://www.ebay.com/itm/351027238632?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This should help me get out of trouble if needed.
I also need to get a recovery kit, but I haven't decided which one yet.
Whenever I'm digging around this forum I really enjoyed everyone's pictures from their trips and projects. I'll try to post mine from every event as well. Hope you guys like them.
Unfortunately my GoPro's mount cracked and I'm waiting for a replacement unit under warranty so all pic's and movies from today are phone only.
We had a lot of fun today and I feel like we could have tried few tougher areas to go trough. Unfortunately we were on a tight schedule today and had to pick up our kids by 3.
Videos are still uploading. I'll try to link them tomorrow evening.
ifixpc
Thank you!
I run the positive to the radio power cable - turns on/off with the car. (had to remove internal battery from GPS to get it to work this way)
Negative to one of the grounded bolts in that area.
There's absolutely no need to get it all way down to cig. lighter.
Gps was mounted on double sided tape to get proper alignment and then used two part glue in few spots to keep it in place.
If this GPS give's up ( hopefully it will not) it will be as simple as a 60 sec dremel job to grind glued areas.
FullMonte
Great pics man! Can't wait for the vids! That winch looks pretty generic.. Do they have a harbor freight where you live? I mean if you're going to spend that much money, you might as well have a store to bring it back to if it fails. Harbor freight has a warranty that you need to purchase but it's peace of mind in my book...
Eric M
I agree. I've seen a few people get away with the Harbor Freight winches for quite a while. Get some good tires on that thing, ASAP. They make all the difference and you have lots of size options with 16" wheels.
ifixpc
I have harbor freight tools close by. Their winch looks the same as the one from online supplier. I'm pretty sure they're all made based on the same patents in China.
Online sup. has a warehouse close by as well + they also sell outside ebay I don't think warranty will be an issue with them.
I'll post some pics when it comes in.
ifixpc
Some videos from yesterday.
The language you might hear in the background is Polish. My wife and I were both born in PL.
1. Shallow mud bath:
2.
3. My wife trying it out
4. Stream Crossing #1
5. Stream Crossing #2
6. Wifey at spot #2
7. Three wheelin'
8. Stream crossing #3
Unfortunately I didn't have much time today to get them in to one clip.
Enjoy.
FullMonte
they look meaty, just curious what is the reason why you chose this brand of tire? Never heard of this company before..
seth.c96
