Herculining Wood? Or.... For storage setup
RAM5500 CAMPERTHING
OG Portal Member #183
Hey Guys
Almost done building my aux battery / fridge/ inverter / storage unit for the rear seat portion of my Tundra.
Mostly build of 1/2" high grade plywood.
Looking at coating or covering options now..
Really like the idea of a bedliner type, abrasion stain resistant coating. Was thinking of Herculining it. Anyone use Herculiner for something like this? Thoughts? Pics?
Any other ideas?? Open to suggestions!
pugslyyy
Hmm, I'm not sure how well herculiner would hold up on wood. seems like with the natural expansion/contraction of the lumber it would delaminate for sure. Why not good stain or oil finish that will permeate the wood and give good adhesion?
RAM5500 CAMPERTHING
Thats what i thought.. But their website claims it works great on wood. Curious if anyone has tried it in the real world!
As for why not stain... Well... I am mechanically inclined, but pretty pathetic when it comes to carpentry. The bedliner type stuff would hide my horrendous finish work! hahaha!
Thanks
summerprophet
Coworker herculined his wood drift boat, and it is holding up fine, three years later. Herculiner uses rubber particles, which will discolor over time, and may look a little chalky with age.
Arclight
SAR guy
I used Herculiner on the center console build on my old Bronco. I also used 1/2" plywood for the build. It held up just fine. The only issue was that the texture made it hard to clean.
Arclight
XJLI
I used Herculiner on a MDF sub box years ago. It held up fantastically. It was more often bouncing and sliding around the back of my XJ than it was bolted down. No special prep, just sanded.
Kiomon
We have used it in our build in a couple places on wood. We love to and it has stood up great. We used it on a small mini wall near the the bathroom. It's held up great, no delamination and looks the same as the day we painted it. The only big downside to herculiner (and most bed liners in general) is that they fade from UV. If it's an interior piece that doesn't get a ton of son, then it's going to be fine and stay glossy. If it will get a ton of UV you should clear coat it.
Gear
Explorer, Overland Certified OC0020
Line X for a professional look and feel. If you have taken the time to make a quality product don't cut yourself short on finishing it off right. It will cost more, but it is definitely worth it. Welcome back to the forum it's been a while! I have pictures, but am short on time at the moment.
oskarf150
