LR3 Blew a Tire. Can I Get 2?
spikemd
The LR3 blew a tire yesterday, thankfully with me driving and not just my wife. Required jacking up vehicle, removing hitch, lowering spare which is oversized and deflated ion order to fit under the car, inflating spare on the vehicle. The tire is not repairable with a major slice under a tread. Wondering if it was damaged in Moab.
They are Michelin AT2s with 33k miles on them with lots of life left in size 265/65 r18. Tread depth is currently 9/32s with new at 14/32s and the last set of AT2s on the 4Runner lasted more than 80k miles.
I am wondering if I can get 2 tires and then rotate them side to side for the remaining life of the tires, or do I have to buy 4 new ones. I don't want to screw up the center diff.
jymmiejamz
You won't have any problems doing just two. Its common for the front tires to wear much more than the rears in a stock setup depending on driving style.
Ian_Barry
Not So Fast
That's certainly true, and why you rotate tires - to make the wear more even. I will let someone with mechanical engineering chops (not necessarily engineering, but more information available in post #7 by cmb6s assuaging concerns and explaining function of center differential) tackle the exact why if necessary but here's the basics of why this isn't the best call (and at the bottom a viable solution).
You will cause differential wind up (center differential). The drive train of the truck is 4wd - all of the time. The differentials allow the wheels to spin at slightly different speeds to allow the truck to make turns. The differential is not capable of changing the division of power between the fore/aft. What will happen is that you will be requiring the center differential to account for different rotating speeds fore/aft constantly, which is not really what it's good at - but it will work in the short term. I believe the consequence will be overheating and damaging the differential.
The simple solution is have a tire shop "shave" down the tread to match.
Hope that helps,
Ian
jymmiejamz
That's certainly true, and why you rotate tires - to make the wear more even. I will let someone with mechanical engineering chops tackle the exact why if necessary but here's the basics of why this isn't the best call (and at the bottom a viable solution).
I've never heard of any shop that 'shaves' tires. If the OP decides to ask a shop to do this, please film the shops reaction.
The fact of the matter is that in practice, there is no issue with mismatched treads on tires. I have personal experience in 100's upon 100's on Land Rovers with like new tires in the rear and worn tires in the front. From the owners manual...
Ideally, tires should be replaced as sets of four, but if this is not possible, replace the tires as axle sets.
spikemd
Thanks for the replies. It's a moot point now since Michelin discontinued the AT2s I bought. But Michelin and America's Tire are stepping up and taking care of me. The tires are at 9/32s from 14/32s so they are giving me 60% return on the 3 good tires, 100% on the blown one and I am getting what I think is the best all terrain tire, the new BFG AT KO2 in 265/65 r18s. I am also getting 5 this time to rotate all around.
America's Tire also set me up when I blew out 2 sidewalls on my Revo2s and I stepped up to BFG KM2s on the range rover. Highly recommend them.
Ian_Barry
Thanks for the extra information cmb6, very good to know.
The same is true for the front and rear differentials?
Ian_Barry
RE: JymmieJamz
I suppose the center differential and the axle differentials operate differently. In your experience have you seen running mismatched treads on the same axle? What did that do to the vehicle's drivetrain?
Also, on less mechanically advanced 4wd systems have you found different results?
Ian_Barry
Thank you for replying.
I'm not sure I fully understand why you couldn't cause the multi plate clutch to bind, but I do understand why it's not likely.
Do you know what the maximum torque split fore/aft is in the LR3?
jymmiejamz
RE: JymmieJamz
I've seen Land Rovers come in to the shop with tires that a completely different diameters and none of them have had any driveline issues that I know. Everyone seems to be overthinking this IMO.
mowerman
You are correct there, there is a tolerance in the drivetrain to allow for a 3% variance in tyre diameter bother forward/ aft and across the axles, this is to allow for production variance within the tyre (manufactured tyres are rarely the same diameter as each other) and to allow for different wear rates as described in the OP, and of course to prevent differential damage should a tyre be under inflated.
This comes from working for Pirelli for 10 years supplying JLR with fitted units.
4x4x4doors
Just FYI for others following along, Amreica's Tire is Discount Tire on the east coast.
JimBiram
Be sure to buy their tire warranty. They have replaced no less than 8 Cooper Zeon tires on my LR3 over the years and all it costs is the price of a new warranty on the replacement tire. That is why I buy all my tires there.
Every Day is a Good Day Surfing...Some are just Better Than Others
V45W_Proto2.5
