FS Maine: 2000 limited Toyota 4Runner, Beautiful California Girl
QuadsBC
This is extremely bittersweet, I love this rig but with a 3rd child on the way and a 75lbs Labrador this just doesn't have the room for overlanding. I've since bought a doublecab tundra and it's a great truck but it's no 4Runner. I've owned the 4Runner for a little over a year. Bought it stock with 226k on her from California and had it shipped to me in Maine. It looked like a time capsul (I'd still eat off the engine) zero rust, clean interior and the engine looked like it came from the factory. There isn't any rust, you can see the original frame sticker and paint pen marks. Fluid film was done to the entire underside including in the frame rails. I never went muddling with it, it has seen mud but I hate cleaning mud from under the truck. I built all the armor and roof rack for it. The skid plate mounts to the new front cross member and can be removed without removing the bumper. I took the mid plate off for more visibility in pictures. With it installed you can't steal the cats. The front bumper has been designed to sit as close to the truck as possible for better approach angles. It also has a 2" receiver and recovery points. The rear is extremely high clearance I trimmed part of the pinch weld to gain clearance. Recovery points and 2" receiver on the rear as well. Also designed it to be lifted with a high lift jack. Bolts to all factory frame holes. Sliders are 2" Dom square tubing with filler plates to keep the kicked up rocks off the paint. All the armor has been well thought out. The roof rack is a modular design and mounts to the factory rails. I have 3 more rails that will bolt to a cvt mt rainier tent. I don't get any howling and on the last trip I got 18mpg at 80 mph with the rack installed. I've also done the major maintenance for the next 50-70k. Whoever buys this truck will own a very reliable and capable family rig. I will be sad to see it go.
Specs:
2000 limited
Auto 4x4
236xxx
Maintence done:
Valvoline oil every 4k
B&m transmission cooler installed
New radiator (never milkshaked. Purchased with original radiator and quickly installed the cooler in fear of it mixing. 2 days later radiator cracked! Talk about timing!)
After the near miss of the radiator, no chances taken. Replaced lower ball joints with oem joints
Replaced inner and outer tie rods (555 brand)
New pcv,
New air filter
Have a new fuel filter for the next owner
New pads and rotors
Po said last timing belt was done at 180k
The normal car guy wash, clay bar and wax treatment 3 times (fall, spring, fall) with normal wash and wax monthly
Mods:
Full armor, front winch bumper, sliders, rear bumper, 3/16 and reinforced front skid plate belly plate, gas tank skid plate.
Toytech boss front coilivers 650lbs springs
Land cruiser 7 wrap rear springs
Bilstein 5100 extended travel shocks
Warn m8000 winch with switched solenoid.
Under hood switched led lighting
Amber led light bar
Led puddle lights on all 4 doors
Extra led lighting on tailgate
Window visors
Cbi ditch lights with 18w led flood light pods
Group 31 battery
Constant switched rear power outlet
Husky floor liners front and rear
Uniden 520 pro xl cb radio
285 75 16 fierce attitude mud tires 2000 miles old 1.25 spacers
Some more stuff I'm forgetting...
Asking 9k OBO
Pictures:
QuadsBC
Under hood
Under the truck:
Looks wicked dirty but that's how fluid film works. It accumulates dirt and dust to create a protective barrier against salt and rust a quick wipe with a rag and the frame is black. Obviously once you do that apply more fluid film to protect again.
Tone615
Restless Traveler
If flying into Maine, which would be a close airport to you?
Or, could you provide a zip code for shipping/carrier bids?
Thanks!
QuadsBC
You'd be flying into Bangor international and I can pick up located at 04679 southwest harbor Maine
For reference it cost me 975 for this come east and my tundra was 1000 from Texas to Maine
QuadsBC
Forgot to add if I get asking price I will include a matching 4.10 e-locker 3rd member, rust free housing, wire harness, switch and ecu. Just about everything to lock the back end
Tone615
Restless Traveler
Big help, thanks for the info! Looking into those options now.
Will PM if looking to make an official offer, but by the looks of the rig I'll need to act soon!
V45W_Proto2.5
