2010 patriot soft roader build.
jhill15
I just posted over on your thread! Seeing that snow pic and going out in the cold to go to work really makes me wish spring would hurry up lol!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
jhill15
Some measurements.
Front passenger
Rear passenger
Rear driver
Front driver
Before
After
tommudd
Yes center of the wheel to bottom of the flare takes the height of the tire out of the measurement
Going to look at one today and want to see the difference
Looks good though!!!
jhill15
cool.. grab one from the center of the wheel when ya can! I want to compare....looks awesome btw!
Thank you!!! I got some measurements from the center of the wheel...I forgot to take pics though lol. I was getting off work and had to hurry to pick up our chinese food....good news is the sesame chicken was amazing!!! I'm going in the morning to get it aligned so I will snap some shots.
jhill15
awesome...do it ride the same?
Thanks man, No its doesn't ride the same at all. It has a thumping in the front end...and I was just denied an alignment. They said that nothing could ever be changed on it with the new coils...im calling b.s.! People install stu coils, and the rro, and can get an alignment...i'm a little pieved at this shop! They seemed really knowledgeable when mounting my tiresn
Jakes01234
I thought they were replacement coils just from a different sub model? Maybe they can't set caster/camber but toe is always adjustable.
tommudd
Yes Stu includes the bolts, RRO sells them for like 35-40 bucks I think or was about that I think
Here is from Stu's site
This kit contains:
Front Coil Part No# CRDSTU 06 (x2)
Rear Coil Part No# CRDSTU 07 (x2)
[These coils are only available in black.]
Front Camber Bolt Part No# CRDSTU CB114 (x2 pins)
Camber would be the main one to get right on or as close to center specs as possible , ten set toe and should be pretty good over all
Like the KJs etc if toe and camber are in you're good
kojackJKU
Autism Family Travellers!
The Bolts are included with RRO, but they sell them separately as well...because in the beginning stu's did NOT include them.
PNWav
