'Ruby' the big red GMC Savana!
straker101
After inspiration from a few friends with amazing vans, and then obsessing over the threads on this wicked website, I decided to trade in the Toyota Tundra and get into the 'van life' myself. Luckily, I was able to sell my pickup for significantly more than what I picked up the van for, which allowed me to spend a decent amount of $$ immediately on the customization in a short span of time (all within a few weeks). Super happy I went through with this as we now have a very capable vehicle for adventures with the family and dogs and I have plenty of room for storage and transport of gear for my stand up paddle business.
This was a super fun project, and I'm hoping this thread will help anyone out there looking to get into a Chevy or GMC 1500. I'm new to posting in forums, but will do my best with photos and explanations. So here we go...
Prior to selling the truck, I had done a lot of research on what type of van I was after. Originally I was thinking E-350, but decided I didn't want to do the significant work of a 4x4 conversion. I live in northern Canada, so AWD or 4x4 is a must. I also don't do any heavy off-roading so felt the AWD in the GM would suit me just fine. After selling the truck, I immediately started shopping around for a 2010+ AWD Express or Savana. After checking out a few with low mileage and good condition (hard to find as most of these used vans are fleet or work vehicles), I settled on the stock red 2009 Savana AWD. Aside from being pretty dirty, she was in great condition, mechanically maintained, and a very good driver. I named her 'Ruby'!
Here she is leaving the lot:
And in the driveway:
I should mention that before bringing her home, I dropped her off at a car audio store and had a 7" Kenwood touchscreen/DVD/Nav installed with all new Kenwood speakers (6 in total), Kenwood amp, and Kicker 10" Subwoofer installed. The sub went in an enclosure and installed under the front bench seat. I also had a Viper 2-way remote start/keyless entry/alarm installed, as well as a flush mount backup camera (flush-mounted beside the 3rd brake light) that works with the Kenwood screen.
Part 1: Clean-up, floor and passenger rear box
She was a mess so I pulled out the seats and all the rear plastics to clean up all the grease, saw-dust, etc. The van had a stock insulated vinyl floor which had some minor tears. I left the floor/insulation in.
My plan was to build a new floor on top of existing and build new boxes/supports on both the rear passenger and drivers side. After determining that I didn't want to mess with the venting/AC, etc on the drivers side, my plan changed to customize the passenger side only.
With the plastic out on the passenger side (and reinstalled on the drivers side, I custom sized a sheet of 3/4 plywood to fit from the rear door threshold to about halfway under the 2nd bench seat. I had to cut access openings so that the second bench could easily be removed/installed. At the same time, I started to build the wheel well box/support. Before building the box, I insulated around the wheel well for noise dampening. The box was not easy as everything had to be cut as I went. I basically used three 1x4 lengths to anchor the box the secondary sheet metal around the wheel well. From there I just eyeballed, measured and cut as I went. The box is flush with the wheel well and goes up to just und
er the level of the window. Its length runs from the rear door and stops flush with the trim at the side barn doors. I left an opening in the box behind the wheel well for storage and to access the stock jack and tool location. As I finished sections, everything was wrapped and stapled with heavy duty indoor/outdoor carpet purchased at a local hardware store.
Once my plywood flooring was level (I had to use timber shims in some places to level out) I installed heavy duty rubber click-flooring and cut to size. This just floats on the plywood and was super easy to install. Very happy with how it turned out. To make it all look clean I used 90 degree 3/4" length angle aluminum for all of the edges and a industrial aluminum door threshold to eliminate the gap between the new floor and the rear doors.
Sorry about the sideways photos. Not sure how to change that. They aren't sideways on my computer!
straker101
'Ruby' the big red 2010 GMC AWD Savana
Part 2: Storage/Camping Platform
For platform supports on the box side, I just wrapped a 2x4 in carpet and fastened at the appropriate height to the box. For the drivers side, I used some awesome adjustable supports that my neighbor gave me (she found them at a yard sale). My plan was to use them as board rack arms for my stand up paddle business, but when I became stumped on how I'd support the platform on the van, they were the best solution possible. Just spray painted them flat black and boom! Low profile, easy to remove and super light but very strong.
The platform itself is just two pieces of 3/4 in ply with some 1x4 stringers on the bottom side for added strength. The front section can be removed in second if I want to install the 2nd bench seat. Otherwise, the platform goes right up to the back of the first bench seat. Each metal support is screwed to the floor in 2 spots and one fastener to the bottom of the platform to keep it from bouncing. So far it is rock solid and the whole thing is easily removed in a few minutes. The drivers side of the platform rests with no pressure on the stock trim just under the drivers side windows. I used a strip of foam (pipe insulation) just to keep the rubbing and/or squeaking to a minimum. So far there is no noise or rubbing so its probably not even needed.
Part 3: Roof Racks, Hood, Rock Deflector and Window Vents
As this was all going on, my roof racks came in. I went with a 3 bar Thule system with gutter mounts and wind deflector. 78" load bars.
I also black plasti-dipped the hood (for protection, AND I like the 'murdered out' look!), and installed a hood rock deflector and window vents by Lund. I also plasti-dipped all of the 'GMC' and 'Savana' badging/emblems.
straker101
Part 4: Lift, Wheels and Tires
I knew before getting the van, I would likely go with a 3" torsion key with 1" rear block kit. I was looking at several options and ended up going with the Traxda 4445 kit. I picked it up online at New Level Motorsports for only $210. I was planning to install myself, but didn't really trust myself messing with the pressure of the torsion bars so brought it into the shop. Was a super quick, easy and cheap install.
For wheels, I ended up going with 17x9 ATX198s in matte black. I was originally hoping to go with a 0 or -6 offset, but got a great deal on a set of -12 offset so went with those. Stock offset on these vans is around +30. I'm quite happy with the result. Definitely a lot more aggressive stance than I had originally planned, but I really like the way it looks. Because of the offset and tire size (which I'll get to in a minute), I did have a bit of rubbing so had to do some minor trimming inside the wheel well. I think with a 0 offset, there would likely be no rubbing.
I had a very hard time deciding on tires. I was hoping to be able to squeeze 32" in there, but very glad I ended up going with 265/70r17s. The 32s would have rubbed significantly (with the -12 offset) and the 265s look just perfect with the amount of lift I went with. I was between BFG AT KO2s and Goodyear Wrangler Duratracks and ended up going with the Duras as they went on sale for 25% the week I was shopping for tires (score!). They have a nice aggressive tread and are great on the highway and offroad.
Because of the width of my stance and the tires sticking out a bit past the wheel wells, I do throw a lot of dirt and mud onto the side of the van (when its wet out). I'd like to get some fender flares, but have not been able to find nice ones for the GMC/Chevys. If anyone has a recommendation, please let me know!
straker101
Part 5: Lighting
I wanted to update the look (and brightness) of the old style stock sealed beam units in the Savana, so I installed some black JD Speaker plug and play LED headlights. Super easy install and immediate upgrade.
I wanted some LED fogs as well, but didn't want to drill right into the bumper and didn't want to install a big brush guard. I found a mini steel black light bar on Amazon for under $100 which screws into your front license plate holes (I drilled two more points into the bumper to make it rock solid) and attached two 4" LED fog lights (18W). I like the low profile look of the bar. I also picked up a wiring harness from Amazon with laser 'Sasquatch Lights' rocker switch. Because everyone needs Sasquatch lights.
straker101
Part 6: Ladder and Future!
My drivers side ladder from Aluminess came in the other day so I installed on the weekend. Very happy with how it turned out. The thing is feather light and rock solid!
The only thing left (for now) on my wish list is a rear tire carrier. I have a full size spare on matching rim that I don't want to mount under the van, but I can't seem to find anyone that makes a rear carrier for this van. Aluminess used to but discontinued manufacturing of it because there wasn't enough demand. I did talk to them and they said if I could find a group of 10 willing to purchase, they would do a custom run. So let me know if you want in!! The only other options that I can find is a complete new rear bumper with tire rack (way out of my budget right now), or the hitch-mounted 'Hitchgate' by Wilco that actually does look pretty sweet as it is a swing-away like the bumper mount carriers. Anyway, I'd prefer to go with Aluminess if they would make me one so hit me up if you're interested!!!
dleeallen
Looks great! I just picked up a red 2014 Chevy LT AWD so it's great to see what a red passenger van can look like done up. Definitely better at least get some mud flaps on there. Mine is all chewed up along the rockers because it didn't have any flaps on it. The paint on these vans doesn't seem very rugged!
I like your platform and side storage box set up. I had been checking out LYlqoY2Fo's set up and thinking of copying it but kind of like the simplicity of keeping the left side stock. Any pics or details of the box build you can share?
straker101
Thanks! Yeah I'd like to find some fender flares for sure. I plan to rocker guard the rocker panels and bottom trim as well so that will help protect it a bit.
I was on a mission when building the box so didn't take a lot of photos along the way, but will take some more detailed shots as it is now so you can get the idea. I basically just screwed in 3 pieces of 1x4 strapping to the steel then used some 2x4 as reinforcements and built the box as I went. Each piece of the box was added as I cut (I didn't make the box outside of the van then install it). Basically I made the side of the box first, fastened it to the 2x4s, then made the front, and top. I carpeted every piece individually before fastening.
DogCrazy
Can you give more detail on the rubbing? I know of at least one member with a 2" lift running 17x9 -12 offset wheels with 265/70R17 tires that did not report rubbing. I'm looking to do a similar setup shortly and want to have an idea what needed to be modified... I'm planning on going with the KO2 for my van.
Looks awesome!
straker101
Looks awesome!
Ya no problem...the rubbing was only occurring at full lock and sometime only while pulling up to an incline. All I had to do was trim some of the material inside the wheel well right behind the front tires, just inside the fenders. Most of it was just easily cut off with tin snips, and there is a small plastic piece that I also cut away. Literally only had to take off a couple of inches of material.
I took some photos, but really hard to tell what I did without any before shots. Hope that helps. Fire away if you have any more questions.
Petersmithinak
