Fat bikes
rruff
it was sure evident on any climb. I basically lost a gear or two compared to a "regular" fat tire, which is about 29" in diameter, where the Krampus was in excess of 30".
You mean you were actually slower on a climb? You'd lose nothing on a climb from the size alone. Physics. And this is verified by people who've tested them with power meters, and racers too. On some surfaces you gain speed from better roll over and traction. Acceleration and quick turns are where you lose a little.
DaveInDenver
Middle Income Semi-Redneck
Indeed momentum works both ways, slower to accelerate, slower to decelerate.
You guys might find this interesting, a write-up done by Schwalbe. It was pre-fat bike but the principles still hold. There's charts and everything! Big (width) and low (pressure) are where it's at. There's a limit to that, they are comparing fat tires 2.35 to skinny 1.7...
View attachment Rolling_Resistance_Eng_illustrated.pdf
rruff
Yes, good test! I've seen that before, it's been around awhile. It would be awesome if they could do a similar study with Plus and Fat.
The main take away is that even with normal sized tires, the lowest pressure they tested (21 psi) was fastest on both gravel and grass.
DaveInDenver
rruff, I think the adoption of tubeless and the ability to run low pressures has pretty much proved that. I'm not convinced that taken to the extreme with fat bikes that it holds but it seems the sweet spot falls about 2.2" to ~3" for an all around tire for most situations.
p nut
butter
I think the sweet spot correlates pretty tight to terrain. Typically, 2.4" is the sweet spot for me (a proper 2.4", like Ardents) on most trails. But there are places, rougher, looser trails, where 3" or 4" tires excel. With the advancements in the fat bike wheels/tires, I've actually enjoyed 26x4" tire set up. Paired with some decently light wheels (ones I've got are 2,200g) and light tires (Jumbo Jim), it makes for a pretty nice, go anywhere set up. I also don't ride with any sort of suspension, so extra fatness helps that much more.
DaveInDenver
I run a 2.4 front and 2.2 rear (both plain old 29). I'd run something larger in back but my frame is old skool and that's as big as can fit. When I say all around I just mean a quiver of one. Maybe I'm wrong but looks to me that all the people trying to push fat bikes into regular trail duty aren't having much fun after a couple of hours. That's why I say a plus bike might be closer to ideal, if you can utilize the fat-ness anyway.
p nut
butter
For trails around you and I, fat bikes on regular MTB trails aren't that much fun--you're right. I rode Heils and Devil's BB last year, and glad I wasn't on my fat bike (except a couple sections where it got pretty chunky). My main ride has 29x2.4" rear and swap between 29x3" and 29x2.4" up front, depending on trail. I actually had a 26x4" up front (2.4" rear) for Porcupine Rim, which worked out well. I wouldn't be unhappy with that set up for year-round riding.
_
Good thing about fat bikes, though, is you can swap wheelsets for each season. With bikes like Suzi-Q and other narrow q factor'ed frames, they're becoming even more versatile.
_
Speaking of fat bikes, I just saw this movie. Can't remember where I found the link, but it's worth a watch. Crazy how many rode on regular mountain bikes.
[video=vimeo;84178875]https://vimeo.com/84178875[/video]
DaveInDenver
That Tumbleweed and Suzi-Q do look great on paper. Having non-fat bike hips makes fat bikes a real specialty for me. I dunno, I like my bikes like my truck, throw backs. I guess I'll be dragged into the modern world kicking and screaming. :)
p nut
butter
I've resisted a lot of modern techs as well. Fortunately, there are lots of options in the "modern retro" genre.
_ My Jones
_
Blacksheep isn't too far from you, by the way. :elkgrin:
DaveInDenver
Actually James @ Blacksheep fixed my Rhygin when a weld failed, the top tube at the head tube. That was about 15 years ago. Still a faithful townie. Plus Metax tubeset, so no rust ever! Yeah, it's about 2 sizes too small. That's a 17.5" frame on 26" wheel, rides more like a BMX bike!
Loves me them Jones. That's kewl.
Yeah, you know I'm all about retro. Well except for the belt drive. And FOX FiT4, gotta have that. Oh and Paragon sliding dropouts. But nothing else modern.
Christophe Noel
Did my first ride on my Mukluk fitted with 45mm 27.5 WTB Scraper rims and 3.0 Ranger tires. Pretty darn fun. I almost went with 29+, but I'm glad I didn't.
Eagle05
I've never owned a Fat Bike, but almost purchased one a few years ago before deciding on a 29er with studded snow tires for my time in Alaska. It was loads of fun in -30°, but if one of these AWD fat bikes been around (and assuming I had the spare change to throw at it), I think I would have been quite happy.IMG_7671.JPG
http://christinibicycles.com
dhuss
