CaliMobber
Its been a while since Ive owned a edgestar but you side vents look different also? maybe?
Thanks for the update. interesting changes.
@JM Wands, I wonder if the 'mode' button has your fast freeze option?
edited to add-it also shows how to set different low voltage cut-off voltages. I don't recall reading about changing the value anywhere.
Anyone having luck lately? I haven't found any scratch & dent models in months.
So I'm trying to get a little more fluent in electrical, and as I do this I realize it's been my tendency like a lot of people to "overfuse". I now have a dual battery system and my concerns over running the system dead are over (was ruining a single dead off a day plus of running the fridge), knock on wood.
I ran 10 awg off a 100 amp fuse block and read somewhere to fuse it with a 30 amp fuse. That will protect the wire and hopefully prevent any dangers, but after looking through a lot of this thread (not going back through all of it), it seems a little overkill for something that only draws 5 amps or so.
I've read guys were having some issues with too thin of a wire gauge causing a low voltage cutoff, so will putting a smaller fuse, like say a 10 amp effectively cut the wire size to 16 awg?
Lastly, any issue with keeping the 30 amp fuse? I'm unaware if the fridge has any protection and yes, I'm too lazy to go look
Has anyone purchased one of the fridges off of openbox recently? I've been looking since before Christmas and haven't seen ANY of the models com up on their site....
