KarmannMarco
Hey guys. I'd like to ask you guys for some advice before I start tearing my engine apart.
For the past year or so I've had the same constant slow coolant leak coming from somewhere on the front or rear of the engine on my truck ( 96 SR , 3.5L Dual Cam )
I've never been able to pin point it and I've never seen it physically drip but coolant spots on the driveway under the back of the engine/bellhousing area and disappearing coolant don't lie.
The coolant loss has been so slow that I've not put much effort into fixing it.
Until last week when on my drive home from Denver about 10 minutes from home I saw my temp gauge start to rise. It never got past halfway the middle and H but it was enough concern for me to pull over and let it cool down rather them forcing it home and possible causing expensive damage.
I popped the hood and observed what was going on. There was steam coming from underneath and back of the intake manifold and the truck was about 1/2 gallon low on coolant.
After a few minutes I topped off the coolant and drove home with no issues and just as I pulled into the driveway it did the same thing.
The obvious problem is that my small leak turned into a good flow of coolant coming out of the engine.
Now I had always assumed the leak came from the "O" ring in the pipe under the intake manifold.
Could you guys suggest every possible likely place coolant could leak from the top and back of the engine?
I'd like to order parts before I tear into the engine and take off the intake manifold.
Part numbers/ links / suggestions / pictures etc... are all welcome.
This was bad timing as I was about to sell this truck at the end of the month and I want to make sure this isn't an issue for the future owner.
Thanks in advance!
Thanks in advance!
