Now the big question
van vs truck
How is Wind noise in the cab down the road?
Do you miss the pass through?
Cab comfort for long drives?
Other + and - ?
I’m looking at truck camper setup I think the comfort and quietness of the cab would be better in a truck, but man do we love to pullover park and crawl into bed without going out.
Van vs truck...... that's a hard one. They each of their pro's and con's. Remember that we owned a high roof Sprinter, so we are comparing to that (for the most part). A lot of these pro's and con's can be switched depending on what's important to you.
Truck Pro's:
- Much nicer drive, it's very quiet and very solid. You do feel more bumps because of the solid axles, but those solid axles mean strength.
- Beefy 4x4 system
- Does not get blown around in the wind - this on is huge for me. It makes driving so much more comfortable.
- Super quiet compared to a large van
- Meant to be driven off road with the body on frame construction
- Because it's built for more abuse, we have more comfort adventuring further into the backcountry
- With a popup camper, you have a lower height which is usually always good
- Overall, more ground clearance
- Depending on the van, trucks have way more affordable after market parts
- Driving area is separate from living area (safer for accidents, no noises while driving)
Van Pro's:
- Easier to go from driving to sleeping
- Easier to store larger items
- Faster getting in and out of the van vs in and out of a truck camper (van doesn't require stairs)
- Probably better MPG
- A lot of times, looks cooler
Truck Con's:
- Worse MPG's compared to our Sprinter
- Takes longer to go from driving to sleeping (about 2 min vs just walking in)
- You have to be more precise with packing, we use our flatbed underbody boxes for all of our gear which get stored in individual bags vs just throwing bins in the back of the van
- Much heavier than our van was
Overall, I'd say we like driving the truck more. The big things we miss with the van are the simplicity of the space (big garage space for bins and easy to get in and out of the van). But having the true 4x4, body on frame, doesn't get affected by side gust of wind, overall, I think we like the truck setup. There is no perfect vehicle. What you gain with choosing one, you are losing on something else. It's all about what the most important items are and which one satisfies that the most. For me personally, I love having a truck (outside of the MPG's). I think having for example the Ford E350 style van where it's got a true 4x4, body on frame, and can pop up would be an awesome vehicle. That way you can have a permanent bed when it's down for sleeping and just pop it when you are hanging out so you have standing height. But then you are driving in your living space, so that can be both a pro and a con!
Wind noise is nothing when there isn't wind. If we have a head wind, you can hear more noise in the back of the cab, it's not terrible, but it is louder. We had wind noise with the van as well with headwinds and having the large interior of the van probably was louder than our camper.
Do we miss the pass through...yes and no. Yes because of simplicity but no because you could hear every rattle, squeak, etc while driving.
The truck is very comfortable for long drives. Because it doesn't get affected by the wind nearly as much, I don't have to be stressed while driving.
Let us know if you want more specifics on pro's and cons. We can always chat on the phone or something if you want to throw ideas around about the nitty gritty.
