Water container recs/stowage of them...
rayra
No. That is a milspec scepter water jug / MWC. Same overall dimensions as the milspec MFC, with a single handle and a totally different cap.
This is a 'civ' Scepter 2-L water jug -
https://www.tractorsupply.com/tsc/product/scepter-5-gallon-military-style-water-can
They're wider at the base, to make them tougher to tip over. Same with their 'civ' fuel jugs. They're trying to not get sued out of existence, like Blitz.
But it means their 'civ' jugs dont fit in any standard jerry can holder / rack.
whitenoise
If I had a JK I would do @Dan Grec 's setup documented here minus the $$$ UV purification system and level gauge. Running water is fundamental to camp living so it is totally worth the cost: http://theroadchoseme.com/diy-4x4-water-tank-pump-filtration-and-treatment Supplement it with a single 3-5 gallon container stored inside the vehicle for emergencies and/or in place of a level gauge.
This has worked for him living full time in his JK driving around Africa for the past 3 years, so it will probably work for you too.
Dan Grec
Cheers. The system has been brilliant.
As you said, I would skip the level gauge next time. Once you live in it long enough, you get a good sixth sense for how full it is.
For the "emergency" extra amount, I have a black bag I use as a shower than holds 10L (2.6 gal). Once or twice I pumped it into the water tank so it was filtered and UV treated then used it for drinking.
-Dan
Overlandtowater
Thanks rayra looks like Im going to have to make a trip to TS.
St8ton
I'm currently using this scepter with a rocket pump I made. It's working fairly well. Stores nicely and provides 5 gallons of water. I connect a hose to run the water out of the vehicles to cups or pots...however I need it.
krick3tt
Tried to carry a Scepter can on my roof rack horizontal. In 75 miles I lost 1/2 the water, won't do that again.
carbon60
The Scepter MWCs are airtight, let alone watertight, when properly tightened. As with the MFCs, you end up needing a weird tool.
Never needed a wrench for either MWC or MFC. If you use a wrench to tighten an MFC container you risk breaking the gasket retainer inside the cap. Never more than hand tighten.
carbon60
Both types always leaked without some extra muscle, for me. But once snug they never leak. So YMMV.
krick3tt
I also carry water bricks, they don't leak. That Sceptor that was on my roof did. won't use a tool to tighten as it screws up the gasket. Just won't use the scepter cans on the roof again.
xander69
