2005 Tundra novice build - "The Rez"
Kpack
The deed is done....for better or worse. That was a freaky experience.
y4mZQ-rbQS81RVqhDDkRpICRNk7b22eDr1m_fMNULY0yj3Z-ZjM89wvFl12pRQydlyI-AdIV5t8HhgMGCAhBZ6B5a_pylgDW5PQtntuxfhZlNPkDeqXG5YCv-2cwmh-gV1HmPL_JCQLDTLOrgW9spNbBPMW35Onthec3KzOEQV_sihjYhQBxiMDQEBaFajbitB8K4G4mhkF0lhsvmwjR6U_pA
More details coming in a day or two after I have a chance to wrap up this first phase. The bumper is temporarily in place while I look things over. I still need to drop it again, clean up the cuts, file any sharp edges, and paint. Then it goes back on permanently.
BattleCat
Hell yeah buddy. Looking good!
Sent from my SM-N950U using Tapatalk
Kpack
High Clearance Rear Bumper Install (Part 1)
Purpose: Install a Brute Force Fabrication high-clearance rear bumper with single swing out. This will improve exit angle, protect the rear of the truck from drops, and provide a much better way to store the full-size spare and water, so that I can leave the bed open for other uses. And it looks great.
Cost:
~$1800
Materials:
-Brute Force Fabrication bumper with swing-out
-17mm socket
-Various other size sockets
-Impact gun and breaker bar
-Pliers
-Tape measure
-Flat bar
-masking tape of two different colors
-Cut-off wheel or nibbler
-Fine metal file
-Touch-up paint
-Friends
Background
The 1st gen double cab Tundra has a full-size bed, and sticks out rather far past the rear axle. The body paneling is also very low to the ground, as is the factory hitch. This picture shows the truck before the rear bumper, with 33" tires and 2.5" of lift in the rear.
y4m-HgKFgReHYpQhD2XP0xIFRfUMRxmdyj7bddH4BbOd0i5CRvBaHsteFv3DIBeuwndNSJlBsQB-Zk7upxLh3xevB5CDknSnqWjYAIVOXILVUi_H1OtJbqS23fEsxnMcBVPfW4DeYeIK8B5QcTaUgiU7J5pQkKXhIf6Yn79VADbeXoPpf9tp4KUmBjshuWUNgvJlNi7GZDOQdb__EgdR5SNTA
The height of the rear panel from the ground is ~23"
y4mGOntV4N-HM2gdQ0V3vLp9b7Uo9w8Q1bYK0aMpozcadPm0h86TgplIKiom2Cwf_T7wjmlopWwdfEDs78J04ZwU3b-sJEVaxIehdZl1YDOJTQDynvX9eqvzGdKMsNJqS3lYIv7K5ECFz-kphc3_8NCdWFFxtVmfM1VFvJv6jX-Vgq9p2w0m_yQhirnQpk9VtqDGhBOCzuDNKTIoWIRxeZMBQ
The height of the tow hitch is ~19.5"
y4mJ1FPE1s7CbqW4Iza6pZ9j8oF1pjmJoBBjukEJr6YfMA4M0jzyDOZMjEJ0-fXSKQe9p8H4Zn9BM_hcs2FbCCoBc4sOiYVCPVze_mxep_k77NIRdvZeQewtiJYNqj5kyaCzp0QxqPChGtvkojvGh9x-ATzLw8has1T-TJNnnVWcocGV31R2N_Yk9gXVz0-1BMUvPFyi69pD9p04eB2D0obAw
Procedure:
Remove the tailgate. The plastic guards on the bumper need to come off first:
y4mtT1GNDf3rhB9iWE6Rr6KVTd9txhISSkcgB5gkVd1nkbG_11oRRqwLNiWVCc4fYot_4dRdg2-JMZwTg0JEIPTspw5apX1MKuBPCZ2tMb8Dc3AbUH4sF-1WWSu6ZCIGlUUasExsrpe-TliYJvmy2wzNixsO3mo0LNnItLl06ef7u_1n2SGkrgM_UznhwSxSW10QI5ZIzfY_ZII11BuH3dL8g
Underneath are quite a few plastic tabs. Use a set of pliers to gently squeeze them and push up.
y4mnq-hkaQUoMizlgKal9TxgV6Fx9kEK2EhY62p8wWNEmKgwo0QAcFhDmxQGHFCTm8bzcLONkvQD-IIsSSKAW861tLuIyh9Pk56N2O0OmlS-VeS346OhM85FFJnBVUiLVQlZp-Z3G7kH_Qbo-vmqdvYw7wCKz0zhmLhh3VwuzI0QxqqdOo8nLlv8R65GYfLE7HoLSvVCvuDUFV9xFdpH4sazg
Remove the plastic covers and detach the license plate lights. Remove the bolts circled. The blue ones are large and will require some soaking with penetrating fluid. There are a few underneath as well. Once they are all out, the bumper comes off easily.
y4mbldiyQ7Yy4H0k75gxszrZwcbXjVm953HQ58C4p_CKDPgFZ9u2x1SGbEZpUymDPI6F2ZmYfRq4VmQYbdL8OBiXO5z11LlkZ5xGWQ1Dyvky1Fk9TLtdh0CcGepzYZwLD1Gxp0x-AeIbdhepDUXKvbG-9y6apqwwnVePbhexvyJdtqyKIbrQXFxizMJv5-Vu-45JiMaW6N3ZsdQEEbPjJOh_g
Now you'll see the factory hitch. There are six 17mm bolts on each side holding it on. I soaked mine for several days prior, and they came out fine with an impact gun. 10 out of the 12 screw into welded-on bolts, and the last 2 have removable bolts. Save all these.
y4mIqIZvMFr1rNS9GQE3feXQCzOhaP-DGZVfB6fDHBTWwjAduM6-6bzWhWO7As24iaK8pN1_6gx2PcbaDEegyZQXCkQP_WGSNl9NqufZlnFMJANg-z5QIguL_th8HTF-E2wPkXjCTbeFHBnIvcn8Wqgap1NDYDEgzHY6N0E5ZPiWC5vs8rBVE4EO6tfg4omsYkbbJYsAatH3OS4e2qFfcJTow
Remove the factory hitch and this is what you have
y4mjE5y11pe3l96-NtpZOgnAG3j2OMZw1KIG1NHSLq-JE2KUTHLJYwObTeE5PMW4XlKJX-8wDUPo6SFN3I-KiD2jezDBIGIH3TjSRXOG6AAZSDfXVpDw10vMCItKUA2B_bWB5NOv6ckFXZ8pNAKEYLX_cYjM3a7JudKa_k5ziFu9jN0henxP0Ga8m8SvlhlqtbUVWHwZVJGvpvC3d5hVaLE3w
Now this is where things get interesting. I thought I had taken pictures of all this, but apparently I didn't so I will try and explain. I'll try to show the measurements with the after pictures. Place tape above and below the expected cut area. Use a different colored tape to mark the cut line itself. For the double cab Tundra the measurements are made from the top of the bed rail and down. Use a flat bar across the bed and place the end of the tape measure under it, and let it hang down. Mark in many different areas and use the tape to set the line. Double and triple check. The measurements I used will be shown later.
Wear eye protection (and hearing protection), use some sort of a cutting implement (I used an angle grinder with a cut-off disk....others have used similar or even a nibbler), take a really deep breath, and go for it.
y4m_SICAh3Yyl3DAfY-1HTJGf-ZqLQxQLeuH6PF8nMTB9ItfozVZoO5Qmr2_NsMOj4aglxTkeRILIWwl6rg7r-q4GuRcr_NYHrTbKoOz8oWz-fGyjojPqnadETc8iDX8nriHCbRZZRo_JSbusJ5bjS_zhZmLZ9rn4v-c2Uj_ukDekZ_DK2lpkq9hCmoZiXH2eYmUMpkeQqrxIi8iE3hlvyXrg
y4m0gBlquxvmyQ_BeWJdOvNoAyviQ9aPmi3Fo4oMLCx6MirsZrULR97qgFLRupIaGlBh4vX3bmNl8oB5nMlnosVwFdJnFou32sVLRWBBI73H2M7Y4lzZnLoqwnEsKqVcmicg3x5zKUUeNy94g77WACKbq3Tb_QdfD49SKBAaYN57mlS9t1HmcMegLvKr9CHdWVuWp9ykOK3CV_SPaGDXqoR9A
Here are the measurements I used. Brute Force sent me some pictures showing 21-3/8"s for their cut, but I wanted to leave myself a little more room for error and went with 21-1/2". I probably would've given myself a bit more wiggle room if I were to do it over again.
y4mAIih53pZHKQCF61P4GoBJnIiN8sCOjUII-7UJee5Jm-1rg3IyR7i7T0BHMAHxgzmt6HhlSkpZx-8cFp-816Vab4VT0z9laiH2wE_WrbqyteE4y62ZtL1RMea3xJSsflxBkzkJ08w0ECrEV645VF7gFZ211ROFLBY9FE1GfnAtkExNbVO4GxQ7ViSjgdkUMf-cSvd0dJR8PDK0hCTwdvVvQ
Cut all the way through the rear of the wheel well and take it off. It will be flush with the surrounding bed support beams when it's done. Once both sides are cut, this is what you are left with. And you will be thinking to yourself "What have I done??".
y4mf7GedNJo8qFhLKTdIB5PCoU-YOwx90VdX9VwgHj5EAUsJ0368og0tVmuFJ3pOQFd3vd7OxfAy6Yifw7zOiUYu3_rUrdmyC8-hJMBj9uY6leYbQmXHKP-yWGk-011OyDZNGNJwHeLTSD6BdkOIL_j2ghcvGlekdOvHvyerhzzZf9iyzCdvlEbdRi5JsH0Xcw-qHWnGujJASl-c4aRVsCHRQ
The underside of the bed is painted in primer, and some of this will show between the bumper and the bed. I cleaned it up and painted these areas black.
y4m7A0R7Dg-u-ZQKir4XAFTj1rG0_TssvRd_9XjfKfk3lsoxIU0yGkcjaspUbZaghZSwvy9Em_wq5a4_YNSDlzxPPKz3JuTNNFJQTLoz4bE77HvzM2QqXzIZARnTVRjUnFBpyhPDbw2zW4ECgpQ8Go2vLrZDbRi_tcSXdFtLd3o0NWfsPmF4NRCkBVVV2TlHK1Mxo85ICGtealWLF6Fi6fNWA
Use a couple of friends and test fit the bumper. Adjust your cuts as needed so the gaps are mostly even all the way around. Once you are satisfied, take a fine metal file and clean up all the edge and cuts. Then mask off a bit and paint over the bare metal on the edges.
y4mXpZZqiZYkYwZFtRcOMDTm0Bw07AKX8j3054Ghx_hXyhlgUOAykkel3nJ45V7w_RWW9QtRaqSgdxAFx4cfPuzGYcZrFoi4hGsKWuoeEH_cBBxVtbYU7WAfEu4nRAYh6BB34b7_05W1xkN1MYhLtcHnG7B-TRMJQgJ6cOsXdMU9brwapyZyB7O15UhZXcxi8mc-QrlIwo0pxTiWmm2OdTKBw
At this point the bumper is ready to be installed permanently. Reuse 10 of the 12 original 17mm bolts (the new bumper does not use the two forward most holes). I put anti-seize on all of them and torqued each one to 74 ft/lbs (factory spec).
I'm a complete novice at working with metal and my cuts show it. I'd give myself a 6/10 on my work to be really honest. The cuts weren't totally straight and the gaps weren't perfect.
-Kevin
Kpack
High Clearance Rear Bumper Install (Part 2)
With the cuts made and cleaned up, I mounted the bumper and torqued the mounting bolts down to spec. The second phase is getting everything set up for the swing arm.
y4m2yxoEaGQdRx7-8FAUX5b6RxLPGsTPSesH0MnhxadlSrmYEoNwqN_5WoJ9U_Cr7x1B2uv61rX-zX1NKr179LZnmelQCeJIkdSF8gYoYS-xs2bCZ4_NxhtXLVxh_3liQei9tTCv2uVvOyH7xvKagsoudhzuuDuitgJnqEJPVnVKBfSKzWYiWyN3N2HwKWjWuWq9e6NyOEpo7mvtYXZ9Y19hg
The first step to mounting the swing arm is getting the bearings ready. I used water-resistant marine grease and coated them thoroughly.
y4mLUH5cAfN_K0EPodrvPWskisaxL3fkO-F42qQtvCCeb2Bxou7og05dgSMG80wk7fVAzljVF8bdijl0Z1dV8K9FWwMfZQyC8Bq_n2u9JAKSkNg9S__e6ymKfeH1Hb0o0rmmafeuppkqRtq-cxa-o1Qcn0XUciKhgLTbOnQ8syef1GN7Sa9qVUWmdTCEo_ky0qINg4yAk5wMuNvwnuiMpanZg
The lower bearing goes in first, tapered side up.
y4mKCco7BkmzRD8Ta33DpGXIt5AYZ2-asET2nJV1Ab2zk-NYfb_CQSIN4TbcHfEcwySBbqAmlCSbAlVvoviFHMLmxxf3RqoaLe-oxJlGcHuCis_vWX0I9y1LxavBNEXaJD3eLrqprQM2MQ6Yp-O1btauePZzoDuttn443UKBWEHj-exMB1etkonrYh_wZMl5U2nYG40NfRAZUDX0GbhDpHFPw
The seal goes in next. I had to tap it into place gently with a screwdriver until it seated.
y4maVR73LafgyV4PWdkZT3KFnG-jGRX9Ij7a-Xhcs5Mr_6NrooDXQd6D8xJWi4Vyeav3rnCkZavNNJAFuh2_743AuZ9Dy5IDaiO_tHkGrCQoas2niFRCVmpCAGrcoKRY8JOjCjFNisib6DGyjBpUfdmK_VAdKytSQHsDxvNgxOnoLkp2RCBkmIe5oJzc9eurR35fVazHvAQWpgNCriHVrt_MQ
Fully seated and ready to install on the spindle.
y4mrMxSEvvaCvVSfwC8uzqI_kITAM_ZG21kP9Y9iSayyb1LGm9HajMfeRTKlLnNI-kzXqgcgpLrpu8Dd4sFeIH-fCv7uObEbo8M7wDt9AFn12diPE_FtTFiBe2wCDuHOoYUdBx_kyxa-M23OuGiq6JoA7DNS9IPKm_EfHIDlDcOLwELtQijZDAryecH4SF4F4RUEjJQDbMVkk_kX5cIJsmRSw
The swing arm is installed over the spindle, carefully to keep from pinching the seal.
y4mgMPEMES4B679vQDbR-TP7v1HvkGVScaBMcpX_H9bqX6hEMwNhZwGVFFwGC53pQ5Tnp4prTVV8C1AO4oMJiOQIyU88ZAusCgRsF-8buiRCYQ4P1hH9LeURzIGxKQ-EcatbJrwneMCcKbU1sqzVRFQilxsaj22Z8tFhWVq9AmpMNSmq91TW6Z6zpsWRhwJH7kio5cVlq2RP7AgKiNzqMHALw
Now the upper bearing goes in, tapered side down.
y4mZ72atCkpFWz9xv1WrL2oAd9VZKIeISpjHJ7qVKBG4pk0225sMZpsEsoSnrvXMWlFFtE3bXTWjBsHul2tWSb52o40M-VNAwXzEFMfxRmIytWeJv3gq4yMgOM3MJcYzJI2gLrLXtX2AlyyraKByRl5UGbOB8zHG-rqt6GVZ-MrMN-MrX6mxZ2c6CXzjoe0x0ryWZaCWy4KNc386wTzQmw5Mg
Next comes the large washer over the top.
y4mdIVnbzTCzYZCcons9wFgHGvuZlu7jRGuTr2sNqGxVd_1kziWPq4YHelO-iUZYn7f21HEN-PLGDDkZsUEdVAtXoNN6S3MdABqrl8uaFKmBBASdXrvjcYydFbQdHbnDKG0d7ofcf7Zp0qOOLYjSJG3Ai2QRvUua_urkEYGcGitv5XHe_wq7xT8N-OXc2MlP_-oEOvqSEu11_rXz6ohNxOdGw
I didn't get a picture of the nut that seals it down, but it's 1-1/2" nut. I held the arm in place, and torqued the nut down. I don't know what it's supposed to be at, but I went to 110 ft/lbs. Then the cap and o-ring go over the top and the spindle is done.
y4m2FteOFKZAa38GFucxZrKUq3YtYMrfFZNaO3fA-4boWFyq9hlC9GcZ1a2it26sSvaIgZ6iIwQXqSyrAxhM05-t4VHQ4o_Ll2grQqZU7beNARIDWo3AydJeqiJyla2uyLeftV2HjmRl9-ggSGuagcU0Xuyl-maChcGM2GjFzodSBcoGQKt-NWfGMxouTianPWVwIyxUvxtPY1thGheN-XnAA
The latch is held in place with 4 supplied screws.
y4m3hMNfs3XGmvLuDyL-tVaINA3JoJ6rZjLSLF7U7_SHWRlaDCbw7ClcQ-L7JqcOwMKN1YF_Sv67MaRB1Y6GebNoyXvOE6q0xmIJfIjU9Q3cOJt3ZgIIovZEjZt2-cHNFG25kP_LLB8vUDPYavJ2MqRLv-HbvQ2ecHpnhvNZgzey-oQfNH243MoowcCt0QLBNtiRzhwbobv4Bh3tgJoS_6a8Q
The fold-down table is excellently made from aluminum, and has a lot of hardware to hold it together. The black hand screw holds the table in place when it's folded up, with zero shaking.
y4mE1TvCx8apN9WTL1rjhuB8L8lmiYen8YtcOyaSh9YGWmmC4wxb0Oc43uYzxibQPCdh298VqLdRvT0H3Rw2o2dlG8qSFUW4YtgFYpUJwkZYpKKOgkZQeOVPvFOSGWvZeLzaiKCAy-8XaP00Yv3hocp7vrv3hOlp3dsYVMoheCfyuCLK7E1LAYgaex9b9rgjb94tdnItiMpEBGf6QAG37ksBQ
The lower bolts on the hinges are screwed into tapped holes. The upper bolts are countersunk so they sit flush when the table is folded up.
y4mbFC8he6MLqPuA65P5i42d3m1nB0DP5NS8hckAjRdYuCmfh8TFuq-IGn3RSAnFf6v5rVi2iae4yOLJsZoMOh_q_Pwd_4XgoO6C4EWL08894JRGoiPXnZsVQL574kWhKr8sSntI-QDgRCQH3leni4Pd30cYGoRtm65Vxt20BzF8nXx28rIhF9zw4EC1PUsxVDHgEK2ZHzSFuj5V0B474XedA
There are two wires that hold the table when it's down.
y4mtvwbG_HzXyAQq22G5OZJXIBfoy79qa8rXk0qpUaAwjXCMr4aJjSER-_q_YiHoa8XfKostz1YZs1Qe2mHQSxTVT5FNu2gxLrRoK9boj8uQN_rCYE-9hAt3uwxdQk2UZcC29QES9VzbtchzPU63BO_YbsJovPjiw-pU10G2MGCtcggFRfLsRi0VE2C_3OXu69BkLGKWxQvET_ckxDrpepZ6g
y4mtRg4TgaAcT5S9rp6b_T0tNJ92LIqyG8EeYIALjbqhbSSE3RDVOkatwUlGgOgsuOKEyboahFdx5vpFdQQ532wVZnDnoUbA4NZIesulSYbtWoUbmxcYEIVlOQEinDonrWnyMiuhDX6lRWJbJJsvnHOCNg1PricnJiwIgXizb5-sZPeASCl2mc-YmknlcumBTho4syp4pcKe6-Xx2h8ZYEpRg
The tire mount is held with 4 large bolts and can be mounted at different heights. I mounted mine at the lowest level.
y4m8Vya9dTZXI6AiLWxQGRbeJ3YrUtuc2ITlrvgHCC_FPRAqn4KRHyRRcEAha8ICeTZdmQ5zCbrwBLFi67kc9BI36THMcpd5xXoyXoYfJi3FjQJZl5XAWcG-J_HqU-iQ3_EK3j5sB2OTu_i9KxZNPrjZQ-kZkHSabQB189XWQyo4f0_1cy3Bqe5LIzJHCyPg0q0zBgkA9SWBo1gI7DJ3U9hrg
All done at this point
y4mcDXRFXBAFl_eFpdpiWMQqzLvRh2NEI4cjCSYRnpKYB72wPfFWZiGObpShhFMMWHCMrHJqJzGBfIXThRJySQv3UGjUNSaOVFYCd4UTxH3m5pWCkRuTmEuB88qB8FqA3_ju7Rs8DfLMoIIcySi6JtsxmoQ5jAx6YgHOOhUICknna8yaKxTMd5vQ5oXgR7bOxWrMQYa79eQMO9v_BnIuXjBnw
The height behind the rear wheel from the ground to the bottom of the bumper is now ~28"
y4mCfNlN9hMnO1vpvSgMIC4Z1RZBe49SNUDRKG2M-niyNoSSLLEqVsAqVtDRbdhoCq7ADGPMjquKjfqgAl2z_AsTFEv5No83UXw4nzp-jFYOHrhLUnF9BwL0aAiXpQVjMCMjnVoO9z2sMzNGQ5JapBpUOCqAaOxHG1yd6zOKZSspDe9ol2_SN6hzAUb2yHoJjofjjW_DwiZ_d4Gw2VA6F7sBQ
The height at the rear of the bumper (where the trailer hitch is) is now ~ 24"
y4mKXYF3byYZOmq6VjXwxtkG8Rtav1N2GZWQROyNNKBwjs-JE4SFGzpJV1e9bY8G01a_s8LPnYHX5XFTPadefii1KMKOQ23KOkFd6YACukfBeB56hL6UykWn01lulRK0GRJEv7B7Fp-VsiNVXmNdLg0YURKlWcB_iJchvzx1QMrHjt16Djc8DScFositluYDPZKLHRn2D7SW6skGzQYx3Vd2Q
The new departure angle
y4m1nZZNTCtG-CHkn3eBlpII1f8_QQSUVhq4iKc9eAFeR2NRn9Op_oGCIWnqJGJXeZMzALh-LnB5TDIetOvK62DmH3s-TuNb-8rFbn6oFASBxk8MW0HaCksisWo1EBtBcUJwNZMY0kk_c-4caghudBGPofAlUogxlTyKPX1m17aYksFo3CbqpHVD3osSLylaNeSnzcvtGTVb9yEim5643K0iA
That's it!!
y4mwA52rNmLkcgQ-CqZ-8sje8fxM_yxWUiSupN7qjG-EcyTHGSdK-BM1SIneCeBPr3D4DwaTb_iSotiIfsKeMNv-4Y6g15apMvWprdqmnXJMhFsLlBMWfgXE5qlBkCfKjprKhwElM4cPtQLD2vyHICg_GMjjk08j4pCoBz_rtgS5wtqoD3xzEfbb03Ypsu9ZL8PdYtTydsF7fz7hPP-mvq2bw
-Kevin
tennesseewj
I lol'd at this. I can only imagine the feeling of almost remorse right about here
Looks awesome, though. I love the new stance with the higher departure angle.
Sent from my Pixel 2 using Tapatalk
Kpack
Anyone else going to NW Overland Rally next week? I'll be there for Saturday. Not sure what classes I'm going to take yet or if I want to try to get signed up for a trail run. Hopefully I get to meet a few of you there.
Kpack
I had an enjoyable overnight trip with my daughters, while my wife got some quiet time with the two baby boys at home. We camped in the Manastash area of the Wenatchee National Forest, near Ellensburg, WA. The swing out rear worked great!
The next morning we got up early and packed everything up before most other people were even awake. I wanted to hit the trails before all the side-by-sides and ATV's got in the way. The camping area was a zoo....so many ATV's and UTV's. We did a portion of the Tripod Flats trail, all the way to the branch for Lost Lake (which is itself a super-fun trail, but I won't do it without another vehicle to pull me out).
Aired down to 15 PSI for the trail and it helped smooth out some of the rocks. It is very rocky throughout most of it. Some steep elevation changes, some tight spots between trees, mud pits, and lots of dust.
y4m6tQj0podGzWNeX7dQBk-CMxJ8o9r5kC9dtRHkHe068KkYngBv95cQtbui92uBf1recNeq3x5EDORkjEQFaKnP7wMbzqSx1VZn9GP3q0_GtfGPLf5JIEL9LzYjKcvydVTnu13hDJoNP_Z-MpXwE9LH-4k-xV5f77qpP6EJCIkZMKI4-8XaCKqryfKosBG8sFaIwh2ki3SeYxvARbfvFMwiA
This is about as much as my truck can flex. Had to lock the rear to get traction on the passenger side.
y4mg4eEtETUlPmz7JuAycHd8-QRmV_H4WxsnKKckuP1qvi4okxM9nfKZgX2GmumeQ2DLRSysnehzS2Soz6qV-4Wll11zwsocu0I8fKTK0FHXB3xbpflgG5EO0LZPCDsmsXhoiKZQLTMlvYFw-UGQplT_iw-LY7EBiAt6sirVNRau-tRtsvvMiHgfQsljn3oQJLPVV1WrDHsFD7OvlE89MlN0Q
y4m-TuhXW94q9BVyHCajqk9zswyu6LrvQv_qzo7Ml1s7Szfk-zh1HVjDNLd0IVDxELGEJY4EUxBin3Ql8McWIMOoO9O0Jskomf7MTdyiBlBObG0Xgcv1qosMaU5DAMDUxFU39eswh_z8fdsruCw5QZldeYSLVgSOwiMolIY5guu4McAqhfQ9CaSOD9vsuwK2XJ90ou6I8TX_U7UtjT978RFtg
y4mHl0mAYf5WeR54U4YEhTIPCm4P3p2G5D1ijeQpu_cPAcBL17oAUQIV_flIil8GexQXIYUHt9T_awMXsTOmFxgkrrXagh5AZo8yYPQLvwISbxnMPnCkRVagVLFLRCnghYhCF_jrswwmn84KxIefYe0JTXfPm8XYi8-GT7VohRPMH3MwOMk4ylxav8GBAMhIyZXHXZHL0Qd6pqR0vxGV8kfJQ
We took some video as well. If you have 5 minutes to kill, maybe it won't be a complete waste of your time. Forgive the shakiness of some clips, and ignore all my daughters' commentary.
A few observations
  • The front end is making a lot of noise right now. Any ideas of what might be causing all those pops and snaps? The squeaking is from the UCA bushings, and nothing I've tried has quieted them down. I can live with that, but the pops and snaps make me think something is going to fail.
  • I need to push the front wheel liners back more. Both sides caught the tires today
  • My brakes squeal when they get dusty or when I come to a stop while turning. No idea why
  • My power steering sounds terrible when it gets warm....and I can feel a difference. Auxiliary power steering cooler? Fluid is new, rack needs to be replaced.
-Kevin
Dmski
Envious of that rear bumper. Really well thought out and like how it’s practically a l shaped bench. Also the Manastash area may be one of my favorites to explore and wheel in. Might have to hit you up next time I’m headed that way.
As for the noises, it sounds like it could be a bushing shifting or maybe camber bolts not fully tight? Worth a check on the torque of all those bolts? Squeaking is totally normal depending on the bushing, pops could be normal but certainly worth a check and maybe jacking the truck up to move things and see if anything feels loose.
Kpack
Shoot me a PM next time you're looking at doing something around Ellensburg. Manastash is awesome. I'm going to try out some of the places in Liberty next. My truck has no business being on some of the trails over there, but I believe there are a few that aren't considered to be rock crawlers only.
I've been wondering about my camber bolts. They got replaced a year or so ago and I didn't realize until later that they aren't the same length as OEM. I'm not even sure what they used. But I think the front bolt is too short and that might be part of my problem.
SC T100
Do you have your sway bar connected, and if so, is it with the stock end links? After my lift I was getting terrible pops an creaks, and it was the end links. I replaced mine with SuspensionMaxx extended length end links and the noises all went away.
Kpack
That's good thought, but my sway bar has been disconnected for a couple years now. It wasn't popping like this last time I hit the trails (last year). I'm leaning towards incorrect (too short) front cam bolts, tie rods, or possibly driver's side lower shock mounting bolt (it's OEM, but I've learned from the rear that Icon shocks like 1/2" bolts). Or it could be a combo of all three. Or more.
bkg
Kpack said:
A few observations
on my Tacoma, the combination of Total Chaos upper arms and older-pre-IVD coilovers allowed the front end to droop enough to cause the outer TRE to bind. I ended up installing limiting straps... it's possible that may be part of what you are hearing?
also, check the coilover - my neighbor found out his coil was coming in contact with (something) when cycling.
