workerdrone
Received the 22" stand; it's definitely sturdy. Feel like I could put a couple of big cast iron pots on there, loaded with food and liquids, and it'll be solid. Nice.
I didn't realize for some reason that it would be steel, painted white. Because most of the pictures online are tiny and not very good.
Comes with a canvas storage bag and no assembly instructions, not that they should be needed. Only 5 pieces - the hinged legs, and 4 crossbars which drop onto 4 pegs on the top corners.
Everything I found online before I ordered it said, "The stand height is 32", making the cooking surface 35" high."
Height is actually 34", making the stove top 37" of height - this is great for us since we're tall. But it's a 2" discrepancy - are they all this tall or do batches vary?
Also, it's a 22" stand so, made for the 22" stoves, no? Stove is a titch under 22" but the stand is actually wider than that - and there are no stops on it, so you can slide a 2 burner back and forth, or rotate it quite a few degrees.
If the (thin) rails holding the stove were spaced 1/8" wider, I could get the stove to fall through - which would be scary with big pots of hot food - see photo - again, quite a discrepancy in a metal shop.
Will probably end up buying a plastic cutting board from restaurant supply and cutting it down on the table saw to fit in front/back of the stove - looks like that'll be a 15" x 22 1/4" work surface which is ample:
