Wedge Camper Build
I decided to document the build to the best of my ability in hopes that it could provide guidance for others to follow
SPECIAL THANKS: @Ripcord , andy.and.beyond (Instagram), for collaborating with me on the design and sharing ideas on the builds. As well as GoFastCampers (GFC) for being open about their product and giving me guidance along the way.
Disclaimer: This camper has not been tested in any sort of crash testing, and I would strongly advise that you use it for off-road use only. This write up is simply a guide for something I built for personal use. I take no responsibility for any damage you may or not do to your own vehicle, or any bodily hard you may or may not cause to yourself or your passengers if you decide to replicate this build and mount it to your own vehicle. Be an adult and take responsibility for your actions. Thanks!
Why build one?
- The wait. At the time of this post, the shortest wait time for a wedge camper of this style is approximately 8 months.
- The price. As many of us, I am on a budget.
- It was a challenge. This is something I've never attempted, and I figured the worst thing that can happen is I learn a thing or two.
- Access to tools. I am pretty fortunate with my job, that I have access to an entire aircraft metal shop which is set up for doing just about anything to aluminum.
- Time. I had a lot of time to think about the project, what I wanted out of the camper, and what I was going to use it for. I previously had a topper on my old truck, and having the ability to lock my bike / camping gear up was important to me. We also wanted a fast set up and break down time, and a wedge camper would do just that.
The Design
I "designed" the camper via google Sketchup. I don't have any professional knowledge of CAD, but having used Sketchup for many years for other personal projects I figured it was a good platform to start in. The camper needed to be aesthetically pleasing and flow well with the rest of the truck. There is no hiding that it was designed very similarly to the popular Go Fast Camper, with small design takeaway's from the Vagabond Drifter and various AluCab products.
Frame
I found a local welder in the Sacramento area who made the frame based on the designs I gave him. After a little back and forth, this was the final product, and measurements.
The entire frame is 1.5" Steel Square Tubing. (Measurements below)
The angles on the back / and sides are all 10 degrees. The front is 3 degrees, to follow the rear of the cab. Depending on whether you have a 6' or 5.5' truck bed, the measurements will change. I have a 6' bed, so the measurements below are accurate for the long beds.
Whether you are building this for a 6' bed or a 5.5' bed. You can use the same (top of the frame) width measurements which is 53.25" x 73 and 11/16", which will allow you to use the 80/20 measurements below for all bed configurations. Additionally, you will want to add a 1/4" thick x 3" wide steel sheet that will sit on the top of the frame, and will act as the support structure for the interior portions of the 80/20.
One of the things that I changed with my design that GFC does, is take away all the cross sections. Yes, this might make the framing less rigid, but I also don't have the camper mounted to a long travel Tacoma, nor will it ever see those types of forces put on it. We do light off-roading. This also allowed us to be have better access to my gear, and! It allowed me to put a sliding window on the front of the camper, much like the Vagabond Drifter has.
In order to mount the frame to the bed of the truck I figured using the existing Toyota rail system would be the best option. We welded on some tabs to the frame and used 90-degree brackets to connect the frame and the truck. (See last image in this section). In order to attach the brackets to the Toyota rail system, I purchased these guys from amazon.
(https://www.amazon.com/gp/product/B07BWV49BF/ref=ppx_yo_dt_b_asin_title_o08__o00_s00?ie=UTF8&psc=1
Why build one?
The Design
Frame
