Sparse Gray Hackle
Morgan Freeman Imposter
Thanks! We've been using it quite a bit and it's holding up great! We usually keep our Instagram up to date with "post worthy" photos - https://www.instagram.com/iggy_the_igloo/. You'll be able to see some good shots of trips on there.
We've had to make a few adjustments like add more weather stripping, new blocks to hold up the walls (pushes them out further for better seal), and a few other small things. We did change out the outside drain/water spigot to be a real hose spigot and then changed out the inside plumbing between that and the water tank to be 1/2" Pex. We now have much better water flow outside and it sticks out a tad further to be able to get water bottles under it (this was a big reason we wanted the outside drain is to fill up items). Another big thing we did with that was add heat wire to that plumbing because we've had that section of pipe freeze in very cold temps which then takes away from us being able to drain the system until it thaws. We've also added Reflectix under the mattress to see if it helps make the bed feel a little warmer. We've added strips to the guides on the front inside of the camper so when you raise and lower, they slide on that rather than the wall.
I finally got the courage to drill into our flatbed and install the rear sensors that came on the truck. We've had them turned off and stored by the spare and I finally decided to give it a shot. They are turned out really nice and work perfectly!
We had rock sliders made and welded onto the truck (pictures on Instagram).
We just ordered new front coils and front and rear shocks that are going to make the ride quality so much better and control the back and forth sway. The hope is to get rid of the Firestone airbags in the rear since our camper lives on the truck. They are taking a lot of wheel travel away and we want that back. Should have those from Thuren in 5-7 weeks!
There have been other small things we've done as well, but overall the truck and camper combo have been great. So far, I think we've slept in as cold as about 0F and it was nice and warm inside. The cabover is definitely colder than the rest of the camper which is why we are trying the Reflectix.
Let us know if you have any other specific questions!
Reflextix is a very poor insulator, maybe a R1 - 1.5. I believe you would be better off with a layer of hard foam, with something like Hypervent between your mattress and the foam to deal with condensation.
Scroll down to common uses. https://www.radiantguard.com/collections/reflective-insulation
We have 2” of foam insulation and Hypervent in our TC.
