leeleatherwood
The Nissan VK56VD is an amazing engine, it is best in class. When looking for an engine ideal for off-roading, towing or street driving, the VK56VD is great. We can use dyno statistics and excel to demonstrate this quite easily.
1st Competition:
Often times the Iconic Jeep 4.0 "High Output" found in 90's and 2000's Jeeps has been praised for its generous amount of torque and its relatively flat torque curve. Many people consider the 4.0 as the "Holy Grail" engine for off-roading because of this. The 4.0 HO is a fuel injected, iron block, iron head straight 6. Lets see how the VK56VD stacks up.
We can see that yes the 4.0 HO has a pretty flat torque curve, this is very good.... but so does the VK56VD. We can also see that the VK56VD is making almost 200 ft-lbs of torque at 1000rpm. You will also notice that by 1500rpm, the VK56VD is making more torque than the Jeep 4.0 HO makes total. Max torque of the VK56VD is 413 vs 225 for the 4.0 HO, so almost double. The VK56VD also revs 1000rpm higher and makes much more horsepower.
Conclusion:
The VK56VD is a much better engine than the Legendary Iconic Jeep 4.0 HO in every regards except nostalgia.
Data Sources:
1st Competition:
Conclusion:
Data Sources:
Horsepower and Torque curve for 2016 Nissan Patrol LE (aut. 7) model for Europe Asia
Engine horsepower and torque curve for Nissan Patrol LE (aut. 7) in 2016, the model with 5-door sport-utility wagon body and V-8 5552 cm3 / 338.9 cui, 298 kW / 405 PS / 400 hp (ECE) engine for Europe Asia ..
www.automobile-catalog.com
Horsepower and Torque curve for 2000 Jeep Cherokee 4.0 Limited (aut. 4) model for Europe
Engine horsepower and torque curve for Jeep Cherokee 4.0 Limited (aut. 4) in 2000, the model with 5-door sport-utility wagon body and Line-6 3956 cm3 / 240.7 cui, 135 kW / 184 PS / 181 hp (ECE) engine for Europe ..
